I was thinking about growing sugar beets on my London roof terrace, so I was wondering what temperature it needs. I also have access to a greenhouse should it be necessary.
tropical
  • 107
In regard to the temperature requirements of sugar beets, they prefer an even 65°-80° Fahrenheit (warmer daytime temp) for the first 90 days of growth, at which point the roots begin to swell, and the plant will prefer to stay within 5° on either side of 75° Fahrenheit daytime temps, and the same for a 45° nighttime temp.
As for other optimal conditions:
  • Soil pH - Test your soil. The pH should read between 6.5 & 6.8. Sugar beets will produce poorly under that level, so if your soil reads lower than 6.5, apply lime.
  • Water - Sugar beets need at least 16" of rain to mature, but more is better. I have used about 35" over the entire season (counting rain) with success.
  • Fertilizer - These are heavy feeders. Give them plenty of nitrogen, in a balanced fertilizer, all season for the largest roots and highest sucrose levels.
  • Soil Type - They are adaptive, but do best in a sandy loam with a high organic matter content. It must be water retentive but free draining. I have grown them successfully in a range of soils, but still recommend sandy loam, even over bagged mix (no soil).
Other points of interest:
  • Sugar beets can take 100-180 days from seed to maturity, depending on conditions and variety. Some may take only 90.
  • In limited root space, go with a smaller beet. They take less space and mature faster, too!
  • Watch for weeds, which are the first reason for failure at first attempts on growing this plant.
  • I've noted that there is almost zero pest/disease problems when grown under close to ideal conditions, but watch for slugs, flea beetles, earwigs, and the like.
References/Further reading:
J. Musser
  • 52,241
  • 122
  • 333
