23
One of my pepper plants has started to flower, and the petals are falling off to reveal a pepper growing from that stem - well, at least the first two have, and the other flowers seem to be bulging somewhat in the middle and I assume will therefore produce fruit.
A second of my pepper plants are also flowering, but when its flowers drop off they drop off entirely, stem and all. So far three of its flowers have done this, and there are a few more flowers that don't appear to bulge like my more successful plant.
Should I be concerned about the second plant? And if so is there something I should be doing about it?
mrizz
  • 37
DMA57361
  • 2,695
7 Answers7
17
Peppers are self-pollinating, so in general if you see flowers, they should produce peppers. That said, if there is insufficient air flow around the plant or if it is in an enclosure, etc., it might not be releasing enough pollen into the surrounding air to fall on the stigma.
You can try gently tapping the stalk of the flower or the branch that has the flower, so as to release a pollen cloud around the plant. That should be sufficient to pollinate the flowers.
Lorem Ipsum
  • 11,219
  • 58
  • 95
14
After the suggestions here regarding pollination hadn't helped I continued to research, and apparently it seems that over fertilisation can cause an excess of foliage growth and delay fruit production.
I originally ignored this as a possibility - I wasn't feeding the plants - but then the plant in question (and the one next to it) continued to grow much, much, taller than the flowering plant. After a little investigation it turns out we'd had a minor miscommunication at home and the plants had been given more feed when it wasn't necessary, so this looks to be a potential cause.
DMA57361
  • 2,695
I would also add heat as a possible reason - I see this behavior in the height of summer. Perhaps there is less disturbance (cf. Yoda's answer) but this year I am still seeing new peppers forming on Gypsy in late July. Perhaps they pollinate more easily.
winwaed
  • 20,513
  • 65
  • 118
I use my finger to pollinate the flowers, just gently rub each flower once they are open and pretty soon I have peppers.
boatcoder
  • 151
Flowers not fruiting could also be due to zinc deficiency. Add a handful of ash (preferably wood, else coal) on day 1 and day 3. This will most definitely work.
user20150
I use a electric tooth brush to pollinate my indoor peppers and it works great. You just touch the stem of the flower and the vibration typically releases a cloud of pollen.
Lee
I also use a finger to pollinate indoor peppers. I manage to pollinate about 90% of the flowers and I don't give it too much thought.
