My lawn which is a combination of clover, moss, crabgrass, dandelions and occasionally some grass is going to be aerated in two weeks. I want to know the immediate steps to take after the cores are pulled.
I have read the two best things to do are to leave the cores and to water the lawn because this will help the roots. I have also read NOT to water because it will just re-encouraged the ground to become compacted.
Anyone have insights?
Edit: My goal is to eventually get the soil prepped and ready for growing a healthier thicker lawn.
treeNinja
  • 679
Leave the cores on the grass! Water deeply only when you are able to see your footprints left on your lawn/grass. Great indicator. Use a spade to see how deep the water reached into the soil profile after 15 minutes. It should be a minimum of 4". 6" is better depending on the porosity of the soil.
Allow the lawn to dry out and don't water again until you leave footprints on your grass! Watering a few minutes once every day is promoting shallow roots and the first time you forget to water might stress your grass to the point it will go dormant. Stressed grass can not compete with highly competitive weeds!
Another common mistake is to cut your lawn too short. 2 1/2" is too short for the grasses I am familiar with, here in the Pacific Northwest. I'll go look up your profile to see what types of grass with which you might be dealing. Raise your deck up as high as you can to see if you can cut your lawn no lower than 3". The soil stays shaded preserving moisture and weed seeds don't get enough light to germinate.
If you have the same types of lawn grasses (bluegrass, fescue...) these species genetically have huge root systems. If there is not at least 3" of photosynthetic top growth the plant can't make enough food to feed the roots and you have stressed, whimpy grass allowing weeds to get started in the sparse lawn.
Here is a tip that will make a humongous difference: Fertilize at least twice a year with a slow release organic fertilizer. I used Dr. Earth Lawn Fertilizer and was blown away with the difference in my lawns! A bit more expensive but it lasts longer, adds bacteria that aid thatch-breakdown, and beneficial fungi that help the plant uptake nutrients, water.
Don't mess with moss-killer, that will lower your pH and lawns love a bit higher pH (6.5-6.8). If you want a beautiful lawn you should definitely get your soil tested. Only add lime if the pH is below 6.5 and follow the instructions! Moss is an opportunist...if you water everyday, if you have any bare spots, shade with sparse grass, moss will grow! If you get your grass healthy, mow high and allow to dry out in between watering (about 1" per week...you'll have to train your grass in steps to get deep roots to last a whole week)! I only watered my 'trained' lawns, once per week and they were thick, cool, soft and no weeds. Aerate once per year minimum. You might want to up it to a second aeration for a few years. If you have more than 1" thatch you will need to do it and then reseed, mulch, roll...etc. Lot of work but really is for drastic measures as it ruins your lawn thus having to start over.
Hope this helps, there are more things one needs to learn in order to have a beautiful and healthy lawn! Stay away from herbicides, pesticides and quick fix instant fertilizers that call themselves 'plant food.' Plants make their own food only needing us to add certain nutrients because we start with poor soil, compacted during construction, poor mowing practices.
There are a bunch of great question/answers concerning lawns on this site that will give you even more knowledge and tools that will help you achieve mastery over this 'beast', the lawn.
J. Musser
  • 52,241
  • 122
  • 333
stormy
  • 40,664
  • 76
As stated above, any lawn renovation should start with a comprehensive soil test (available here) for $30 or so. For that money they'll even tell you how much of what soil ammendments you deed to apply.
But IF you are going in blind, it seems almost a wast to aerate and stop at that. When we do lawn rejuvenations, we start with good core aeration (covering areas in two directions), leave the plugs in place, and then seed and topdress with 1/4" - 1/2" of screened, finished compost. The seed needs to be appropriate to your conditions. But again, if you are going in blind, go with a sun/shade mix of bluegrasses and fescues to hedge your bets. Then provide enough irrigation to keep the soil, compost, and seed from drying out until the grass has sprouted and a more standard irrigation regime can help it get established.
That Idiot
  • 7,089
  • 57
Purists I once knew would rake up all the cores and then fill the holes with sand; but that was starting with a pristine lawn. I wouldn't even bother to spend the time and money aerating a grungy lawn until you get the grass to grow. I just bought a pull behind aerator for my new lawn tractor; both of which I had owned before at a previous house. I always just let the cores melt back into the soil naturally: no special watering, seeding, or fertilizing. And to keep the need for aerating to a minimum make sure there are plenty of worms in the lawn.
sborsher
  • 847
Seed does not require light to germinate,it only needs light when it is started to sprout. So even seed which is in the hole left by your pluger,may show growth.
user16374
