What sort of equipment would one need to ensure that plant soil contains the right concentration of the 13 mineral nutrients necessary for plant growth? Specifically, can this be measured in real-time without involving sending samples to a lab?
As far I understand, it's vital that all the following elements are present: nitrogen, phosphorus, potassium, calcium, magnesium, sulfur, boron, copper, iron, chloride, manganese, molybdenum and zinc.
It seems like simply measuring pH gives only a rough estimate and is not a very precise indicator of the various element levels.
J. Musser
  • 52,241
  • 122
  • 333
augustzf
  • 173
Okay to get right to it, no, most of those listed nutrients aren't practical to test for at home.
That said, you can get test kits, for basic info about levels of N,P,K, and pH, but they will not cover all the other elements you were asking about. Basically, if you want to do that yourself, you'll have to actually build yourself a lab. It would be expensive, and each test will still end up being more of a hassle than simply paying someone else who is already set up, and experienced.
In other words, I strongly recommend that you have professionals conduct these tests for you, rather than trying to do it yourself.
J. Musser
  • 52,241
  • 122
  • 333
