The terms 'vines' and 'creepers' are used frequently in plant descriptions. They both have flexible growth and cannot support themselves in an upright habit.
A simple image search brings almost identical results. (vines and creepers) And from here:
All creepers are vines, but not all vines are creepers.
Are there any major differences that can be apparent between vines and creepers? What are they?
J. Musser
  • 52,241
  • 122
  • 333
Vines are not a special group of plants, but - like trees and shrubs - defined by appearances. Vines have long stalks/shots/branches that are too weak to support themselves. Usually vines are divided in two subgroups, creepers and climbers:
  • Creepers are vines that - if left alone - trail over the ground or hang down. If gardeners want them to grow upwards, they must tie them to some supporting structure. Creepers are often used as ground cover.
  • Climbers on the other hand, are vines that can climb on their own. They either
    • wrap their entire branch around supporting structures (like wisteria),
    • grow tendrils (sweat peas) or tendril-like leaves (clematis) or
    • have some sort of special aerial rootlets (English ivy) or adhesive pads (Virginia creeper -> a misnomer!)
    If no supporting structure is available, climbers will "creep" over the ground, too, of course.
Caveat: The naming is not always consistent, "Virginia creeper" is actually a "climber".
Edit as requested:
There is another type of "creepers", namely ground-covering or "crouching" plants without long "vine-like" branches. Creeping thyme is an example.
As all names in this post are based on apperance and not on some kind of botanical relationship, this was to be expected.
Stephie
  • 17,295
  • 61
