Just dug these up from around the roots of a stone fruit tree. Are they maggots? Are they good or bad for the soil around the roots of the tree? Do they harm the tree in any way? If yes to the previous question then how do you treat this?
Tree type: Stone Fruit (Arctic Star). Don't know the rootstock.
There are a number of fruit trees in this backyard orchard. The "maggots" are only around the Arctic Star (white nectarine).
maggots
J. Musser
  • 52,241
  • 122
  • 333
Guy
  • 3,006
  • 37
Those are grubs. There are a lot of kinds of grubs, though, and they look so similar, you often can only tell them apart by their rear ends (seriously, see below)
They feed on roots (usually turf, but also trees, perennials, and other plants) as larvae, and then emerge from the ground as beetles, which feed on the leaves. I think they might be masked chafer beetles. You don't yet have Japanese beetles in Phoenix.
Methods of control:
  • Chickens work after a till, but this isn't practical unless you intend to till the entire area.
  • Adult beetle traps (pheromonal/floral) have worked for me in reducing the amounts of adults.
  • Insecticides are the usual method of control. You may not want to use them in an orchard, if you want to be perfectly organic. I use imidacloprid for grub control in lawns. It's a systemic (taken in by the plant, so when the grubs eat it, they die) neurotoxin.
For grub control, timing is key. The grubs live low in the soil most of the year, below where you can effectively treat. They come up near the soil before pupating, and then when the adults lay eggs, the new larvae start out near the surface before going down. So you need to apply right in that pupae-flight-egg window.
Here's a helpful chart. It may vary according to your location:
Here is some additional information on grubs:
J. Musser
  • 52,241
  • 122
  • 333
I love chickens, but let's not forget beneficial nematodes:
From The Royal Horticultural Society
You can buy pathogenic nematodes, Heterorhabditis megidis or H. bacteriophora, which attack the larvae by infecting them with a fatal bacterial disease. These microscopic animals can be watered into the lawn when the ground is moist and soil temperature range between 12-20ºC (55-68ºF). This biocontrol is available by mail order from some biological control suppliers or some garden centres. The turf around the edge of affected areas should be targeted to deal with larvae spreading out from infestation “hot spots” in the lawn. However, by the time areas of infestation become apparent, the soil may be too cold for nematodes to be effective. As a preventive measure, apply nematodes in July to September against chafer grubs. Nematodes should be applied as soon as possible after purchase, following the suppliers’ instructions for use. It may be necessary to water the lawn before and after application to ensure the soil is sufficiently moist for nematode activity and survival.
I have not personally used nematodes, but two organic plant/turf care companies that we work closely with report excellent results. It is, however, more expensive than the chemical route.
J. Musser
  • 52,241
  • 122
  • 333
That Idiot
  • 7,089
  • 57
Those are Grubs. Grubs are the larvae of Japanese beetles, June beetles, and chafers, among others. These C-shaped creatures feast on the roots of grass and plants. They pretty work similar to root maggots, which also feed on the root system of plants. A few grubs in the garden aren't usually a problem, but if you notice lots of grubs when you turn the soil it may be time to protect your plants by taking action. Apply a grub control product labeled for use around roses, flowers, trees, and shrubs to help protect them from hatching grubs.If you're someone who loves to fish, dig them up and go fishing. They love grubs. They are both destructive. I will go ahead and assume grubs and root maggots can be treated in a similar fashion.
Donna
