I left my home for 11 days and told someone else to water my Peace Lily but she forgot. When I returned the plant looked dead, lying flat and hanging around the pot. I have watered it and cut some yellow leaves, and in two to three days most of the leaves stood upright again.
Yet the stems of some of the bigger ones have bent so much that they are not uniformly bent but they fold on one point that is darker and seems to be damaged (see pic):
Shall I cut it or is there still any chance that it will regenerate? And if have to cut it, should I do it just below the bend?
Martin
  • 641
Snip the unrecovered, bent stems out as close to the base of the plant, just above the soil level, as you can get without damaging any of the other stems. Keep it fed and watered and it should produce new growth without any problem. And maybe get someone else to look after your plant when you're next away from home!
