17
I just planted a cherry tree, and it has a light amount of mulching (mostly fragments of dried-up mulch). I'm not sure if I've mulched enough, or if I can (or should) mulch it more.
Is there some rule of thumb on how much to mulch a tree? For example, if I barricade around it with topsoil, should I put the mulch only on the outer part of the topsoil and on top?
Lorem Ipsum
  • 11,219
  • 58
  • 95
ashes999
  • 2,343
  • 40
For "general" tree planting (care) information refer to this answer here on SE:
  • With the leftover soil make a watering doughnut (approx 100mm high and 1000mm diameter) around the tree.
  • Fill the doughnut with 50 to 75mm of mulch (personally I would use good quality compost), start approx 100mm to 150mm away from the trunk* of the tree and work out to the watering doughnut. Using compost as a mulch in this situation has the added benefit of feeding the tree naturally and slowly. Then add a fresh 25mm to 50mm layer when needed (usually once a year).
*You never want anything covering the trunk flare. The trunk flare needs to "breathe". A sure way to make a healthy tree, unhealthy (eventually killing it, if the problem is not rectified) is to do something like volcano mulch.
Good luck! and enjoy your plumb tree.
Mike Perry
  • 18,467
  • 48
  • 90
