enter image description hereenter image description hereMr. Fuzzy
The plant is healthy otherwise, I see a few ants crawling around on it. Is this a sickness? How do I remove this and get shiny leaves like I see others have?
ychirea1
  • 720
The plant is a ponytail palm or Beaucarnea recurvata a member of the Asparagus family and native to Mexico. The identification is the woody trunk and the long curved leaves. The pest is mealy bug. It also appears to have some hard water deposits or pesticide residue as some of the white stuff is flat on the leaf and some is fuzzy. See here for a similar problem on a different plant.
You can try to control the mealy bug but it's hard because they hide deep in the axils of the leaves
  • Soap and water applied at a rate of teaspoon/quart (~5ml/liter) three times over six day periods will control spider mite.
  • With mealybug I just got rid of the plants as these pests were very hard to bring under control and spread easily.
Other maintenance measure if you decide to keep it
  • Fertilize after a few years with 20-20-20 at half the recommended strength.
  • Top up the soil yearly with a soil less mix
  • Do not overwater, water is stored in the trunk
kevinskio
  • 62,221
  • 167
