I planted 2 cilantro seeds in the same bed a few weeks ago... now I've got 3 distinct seedlings coming up in close proximity. I want to grow the cilantro for culinary use and planted multiple seeds assuming I'd eventually have to thin them.
Is now the time to choose two of these to thin out? One of them (all the way in the back) is starting to develop it's first cilantro-looking leaf.... so maybe keep that one and get rid of the other two?
And to thin, I just get a scissor and cut the seedling a little above the soil?
Becky
  • 841
5 Answers5
I would suggest not thinning them yet either. As @michelle suggested, wait at least until the true leaves appear. You can thin by harvesting once a second set of true leaves develop. (In the time since you posted the question, they may have matured enough to do so). Also, while selling herbs at a market, the farmer I worked for recommended leaving a few plants together (~5) to make them less vulnerable to wind/damage. If one gets damaged or eaten, there is still more plants remaining.
ElizabethEnviro
  • 211
I seed the stuff thick, and never thin. Always seem to get a good crop. My current batch is on its fourth harvest now. I chop it to about 50mm (2") with scissors. Looks like it's getting ready to bolt/flower this time. Freeze the chopped excess spread out on a cookie tray then jar frozen chunks to preserve flavor.
Wayfaring Stranger
  • 2,419
Yes you should thin out 2 of the 3, by gently pulling the seedling out. (Snipping them off would not be the way to go, it may encourage bushier plant to emerge.)
From WikiHow
Prevent overcrowding. Stop the cilantro plants from becoming overcrowded by thinning the seedlings when the cilantro is 2 to 3 inches (5.1 to 7.6 cm) tall. Pull out the smaller plants and leave the strongest ones to grow larger, allowing 8 to 10 inches (20.3 to 25.4 cm) between each plant. The smaller plants can be used in cooking and eaten.[4]
Debbie M.
  • 1,117
Personally, I would leave them a little longer. Things can and do go wrong with seedlings this small. When you have several true leaves on each plant (so leaves that look like cilantro, not the cotyledons like the one you are pinching in the photo), then choose the strongest and thin the others out. I would absolutely snip them off with a scissors to thin. That will cause the least damage to the one you choose to keep.
ETA - One benefit of waiting a little longer is that you can use the plants you thin out. You won't get a ton of cilantro this way, of course, but it is still nice to use.
michelle
  • 9,569
If you have only three little cilantro sprouts, there is no need to thin out the cilantro seedlings. If you have hundreds of cilantro seedlings, then it becomes possibly prudent to thin out the seedlings.
Note that thinning out cilantro usually means to kill the cilantro. Some people move their cilantro to a new location when they thin it out and allow the culantro to grow in the new location. Edible herbs less than an inch tall do not do well when transplanted or moved to a different growing location.
When and if you do thin out your cilantro some day, you can eat it afterwards instead of throwing in the trash or compost heap.
Usually, thinning out plants mean to kill them and let bacteria, not humans, eat the dead plants.
Some plants have stems which are not edible. If it was not cilantro, or a different edible herb, I would not reccomend eating it after thinning it out, but cilantro stems can be eaten.
I reccomend that you not thin them out if you only have 3 plants.
If you really want to thin them out, then do one of the following:
  1. Pinch the plant with your thumb and index finger close to the dirt. Snap off the stem with your thumb and index finger. If you pull out the roots of one plant, it can pull out the roots of nearby plants as well. I reccomend avoiding uprooting them all.
  2. Use scissors to cut the cilantro you want to kill or remove. Make the scissor cut close to soil level.
Rohit Gupta
  • 3,203
