I have been growing this Musa Basjoo plant from a small pup for about three years. It is now 6 feet. This was the first year that I will not be able to bring it inside the house for the winter.
It is just too large. I have been told that these plants will grow back if the trunk is cut, but I don't have the heart to do that UNLESS I HAVE TO. Any advice on how to care for the plant in zone 6 usa, where the winters can be very harsh, even with hardy bananas as the musa basjoo? I have seen trees that are cut return, but never plants in pots. I do not know what to do with this lovely happy plant during the cold months. Should I cut it?
ychirea1
  • 720
5 Answers5
The way I see it there are 2 options to keep this plant growing, but both are going to involve cutting the top back. First, I need to point out one important fact that makes this possible: Banana plants are not trees. Trees are woody perennials. Bananas are herbaceous perennials, much like any perennial garden flowers you might have (hostas, daylilies, daffodils, etc). All the top growth can be replaced every year if it needs to. What appears to be the 'trunk' is just a series of overlapping leaf sheaths. If it's cut back within a few feet of the ground new leaves will grow out from the roots and grow right back.
So, you have two options: One is that you can cut it back to about two feet and tuck it in a cool corner until spring. It will produce new leaves when you put it out in warmer weather. Another option is to plant it outside. If you do this you'll want to watch for the first frost. When that happens the leaves will all die off. At that point, cut down the 'stem' within 2-3 feet of the ground and wrap it in burlap, bubble wrap or similar, then mulch heavily over the roots to protect them from the worst of the winter freezes. Mulched properly, the roots can safely tolerate air temperatures down to -10 degrees Fahrenheit. In zone 6, that pretty much doesn't happen. In spring, the plant will put out new leaves from the base. If you decide to plant it outside, site it somewhere with well drained soil and full sun.
GardenerJ
  • 5,899
  • 35
What is too big about it? It's height or breath?
You can cut back a few leaves or shorten them. It will be somewhat ugly that way, but it will not suffer the die back or trunk cut back and will be fully ready to come back in the spring.
Escoce
  • 6,456
I am with you! If this was planted in the garden and not in a pot then you'd see this thing die back each year to begin anew. This took 3 years to get to this beauty you've got!! There is NO WAY THIS PLANT in a pot will make it without coming indoors for the winter. It IS BEAUTIFUL!! Definitely could use a bigger pot, probably a concrete one that is heavy to support this top growth. Please, don't use garden soil and don't plant in the garden in zone 6!! This dies back in the cold for zones 13-18 (Sunset Western Garden's zones) and this gorgeous plant will never be the same. Have you ever thought about a greenhouse? A tall one? Gotta be climate controlled/heated. I've had an 8'in my home for years, we moved and it got TOO COLD INSIDE and died. Can you raise your ceiling? Grin...this is a tough one, especially since this has been part of your life for 3 years. Personally, I'd drag him back inside, once repotted in a sand-cast concrete type pot possibly 4-6" in diameter larger than the one shown! You can make or even purchase a sturdy stand with rollers for moving. Look at the caliper of that trunk!! Taking indoor plants outside for the summer is the best thing one can do for helping indoor plants last and be vigorous! I always use a shaded porch, never in direct sun. Chopping it down would not be an option for me at all!! I just hope you'll be able to get higher ceilings! Grin. Maybe someone will have a better idea. Do you have a garage? Is it heated? Would it be less of a problem to heat and provide light? I'd punch out my ceiling!! Leave it out and lose it...maybe someone else will have an amazing answer!!
stormy
  • 40,664
  • 76
The center will continue to grow after you cut it back. I cut mine to about 6" tall and pot them up. Them I have to keep trimming back or they get to be an inside jungle quite quickly.Remember that these are really a bulb so the growth will take off from whereever you cut it to.
larry
My potted banana get grows to about 5 feet every year. And every year around October, I cut the top off and bring it in the house. In about a month or so, it starts putting out new leaves.
Mini
