I had two pots of Saintpaulia (African Violet). They've been doing pretty well, lots of flowers, and breeding! However one of them has starting having bugs. When the blossoms open up, there are one or more of the three types of bugs. I've been trying to kill them with a cotton swab dipped in white spirit/ alcohol, it's helped a lot in reducing the bugs, but still there are some. I was observing my other pots, and they were all fine, until the other one had some flowers recently and I found a few bugs there, as well.
These brown bugs are the largest among the three that I see:
bugs on african violet
The second type is the white, small bug, I know there are lots of white spots on this picture, but not all of them are bugs! Just a few. They're pure white, with pure white limbs! Very small.
white small bugs on african violet
The third type that I don't have a picture of, is yet another brown bug, but long and thin, as if it's a very thin, narrow piece of stick, or just a thin thorn.
Is there an efficient, easy, home-made solution to this issue?
This is how the overall plant looks:
And this is the baby pot born from my other pot. They seem to be doing good, as well; but I noticed the leaves seem a bit curly. Is this also a bug/fungal, or is that normal?
Neeku
  • 836
Classic troubles with Saintpaulia in the UK are whitefly, mealybug and cyclamen mite. The latter causes curled leaves, and if left untreated, will lead to distortion of the stems and any flowers will wither. Mealybug would be obvious, you'd see white fluffy deposits on the plant with close inspection - whitefly is difficult to treat, since they're quite resistant to most pesticides.
On the assumption your plants are in the house and not in a greenhouse, you may have to resort to using something like Provado Ultimate Bugkiller, but take the plants outside if its not too cold if you decide to spray them and bring them straight back in afterwards. They won't like being taken anywhere other than where they are, they tend to stop flowering for a while if you change their position. You may need to repeat treatment after 3 weeks if the problem is whitefly. Otherwise, more 'organic' methods of treating them are exactly what you're doing now. Whatever the insects are, the main plant appears to be flowering very well.
