Hello I have an err 1 on my rain bird controller and all the zones work except for one and two which are in the same place could this be a solenoid gone bad. If so I have found the wire that runs out of the controller does this run to the solenoid box?
Brandon
  • 81
Welcome to Stack exchange Brandon. Have you had any frost recently, this often causes damage to solenoid valves in irrigation systems? I would work out which pipes should water the broken zones and trace those back to the solenoid. This solenoid is most likely the faulty part and should be replaced.
Nic
  • 1,043
