I have a small evergreen shrub that gets frost burn in winter. I had been told to use tar paper on it over winter, but I was concerned that since it is a broad-leaved evergreen it might need light in winter. Is there a good way to cover it that doesn't set it back?
Lorem Ipsum
  • 11,219
  • 58
  • 95
J. Musser
  • 52,241
  • 122
  • 333
Personally I would wrap the shrub, but leave the top open to the elements -- unless heavy snow load, damage, is a problem in your area, or the shrub you're protecting is susceptible to snow damage...
Bang into the ground a number of suitably sized timber stakes around the shrub:
  • Suitably sized timber stakes = 1inch x 1inch (25mm x 25mm) to 2inch x 2inch (50mm x 50mm), with a point cut in one end -- this will make driving them into the ground that much easier.
  • Cut the timber stakes to the height of the shrub you're protecting + 12inchs (300mm) minimum -- this will allow at least 12inchs (300mm) of the stakes to be embedded into the ground, thus giving your "protection system" adequate strength.
For maximum Wintertime protection:
  • Install the stakes about 6 to 8inches (150 to 200mm) away from the shrub you're protecting.
  • Wrap the stakes with something like:
    • Burlap.
    • A horticultural thermal/fleece blanket.
    • Chicken wire.
    • Plastic mesh.
  • Fill the enclosure with something like:
    • Non-diseased Autumn fall leaves.
    • Straw.
For minimum to moderate Wintertime protection:
  • Install the stakes as close as you can to the shrub you're protecting.
    • Burlap.
The below articles, documents may also prove helpful/useful:
Mike Perry
  • 18,467
  • 48
  • 90
