I bought this eggplant over 4 months ago but made the mistake of planting it in the back yard where it only got a few hours of full sun, and was also under netting. It's now starting to flower but we are well into autumn now.
An eggplant is a perennial, and I'm wondering whether I can dig it up and pot it, and keep it inside hoping it will fruit. I might order a grow light as well since I'll be moving it to my office which only has a few hours of sunlight.
The leafs are showing signs of aphid damage.
eggplant
Graham Chiu
  • 23,509
  • 96
There isn't anything magical about being inside or outside, the main thing is getting enough light, and that looks like it already isn't getting enough light.
if you need eggplant, and you want to grow it yourself, you could invest in some grow lights and make an indoor oasis for this eggplant... your eggplants will end up costing you US$45 each, but you will have eggplants.
the plants are self fertile, but would benefit from hand pollination (assuming a lack of wind and vibrations and bees in your home.)
Grady Player
  • 5,212
I've just asked my wife (who has a lot of knowledge specific to growing eggplants commercially). When she came across this problem she pruned back the yellow leaves, and the plant was fine - indeed I've seen plants a lot worse then that come back to life just fine.
I very much doubt it will thrive indoors as they require a lot of heat (24-28 degrees centigrade are ideal), as well as light - although it will will probably grow at a reduced rate.
davidgo
  • 5,117
