A friend has just given me an Aloe Vera with pale brown tips. Different sources have lead me to multiple non-conclusive possible causes; mainly: pests, etiolation, wrong type of soil or overwatering...
"The Guide for House Plants", for example, warns that brown stains and seeing insects are a sign of pest or disease (I saw a small insect that looked like a black aphid but haven't seen it again)
On the other hand, the post "Why are my aloe leaves turning white and brown?" here in Stackexchange, points to etiolation as the cause of this, mainly because the center steam is somewhat pale. Yet, in my case, the pale part is mostly covered by the soil.
Moreover, the soil of my plant looks dark and peat-like rather than "desert-like" (which would drain faster), and it also looks pretty soaked. My friend told me she watered it yesterday and that she did it about each 3 weeks (when the soil looked totally dry), pouring about half a glass of water into it. It doesn't sound enough for a 20cm radius pot (near 8 inches) but I could introduce my finger almost through the bottom and it is all wet. So it might have been overwatered... (?)
I'm not able to reach a conclusion and obviously the treatment for each of the causes would be different... Is there any way to nail down the cause?
Martin
  • 641
Based on the plump, browning tips on the leaves, this initially appears to be classic aloe over-watering response. BUT, once every three weeks isn't necessarily an unreasonable watering schedule for an aloe, if the soil is appropriate. As you have correctly observed, the soil is a very dark peat-based soil. It holds water very well and drains out slowly, which is the exact opposite of what an aloe needs. The treatment for this is going to be re-potting into a lighter, free-draining soil appropriate for a cactus or succulent.
Insect damage is unlikely, the black insect you saw is probably a fungus gnat that is feeding on fungus in the damp soil. They're harmless, if occasionally annoying, and they won't stick around once you change the soil.
Etiolation might be possible given the uncommonly yellow tint on the new growth, but it isn't the main problem. The paleness under the soil-line is natural, chlorophyll makes plants green, and plants don't make chlorophyll below the soil.
GardenerJ
  • 5,899
  • 35
I suspect the problem is drainage - are there holes at the bottom of the pot ? If not, the plant is most likely sitting for long periods in wet roots, which it would not like.
If the soil is heavy, that would not help drainage either - but the color does not necessarily tell you there is a problem.
davidgo
  • 5,117
What kind of water do you use? Is it city water from the tap? Too many salts, fluoride and chlorine in our tap water. I would not even drink tap water these days... This is salt buildup in your soil. Use distilled water or (gulp) rain water and never allow any water to remain in your saucer. What fertilizer have you used? That could also add too many salts to your soil. This is purchased, potting soil from bags, yes? Do not make your own potting soil. I know what I am doing and I would NEVER make my own soil. You can also get a sterilized potting soil for cactus/succulents. Water and fertilizer for this guy...hey less is better!
stormy
  • 40,664
  • 76
