An out of state friend of mine has just moved to a new place in Knoxville TN, and her new gardener has offered to remove the following plants (pictured) claiming them to be both poison ivy and poison oak, and charging her accordingly for the hazard.
I'm no expert in ivy, and only have the attached picture for reference, but I don't believe the ivy in question is noxious; mainly due to the old adage: "leaves of three, beware of me".
Are the pictured plants indeed trouble, or is it simply a well established harmless set of plants?
Unknown Ivy
ahsteele
  • 205
rheone
  • 183
I'm in the UK, and we don't have poison ivy, oak nor sumach, so I've never actually seen them. However, the small leaved plant covering the ground in between the Hosta leaves and the one with palmate leaves appears to be Vinca minor, common name lesser periwinkle, usually has blue flowers in spring. The palmate leaved plant looks like Parthenocissus, or Virginia Creeper; there also seem to be what looks like random blades of grass. Images of Virginia Creeper and Vinca minor below
http://www.gardeningknowhow.com/ornamental/vines/virginia-creeper/virginia-creeper-control.htm
http://www.fire.sref.info/plants/vinca-minor/Vinca%20minor%20foliage.jpg/view
I found the link below; according to that none of these plants is poison ivy nor poison oak, but as I said, never having seen the plants in real life, I'm reliant on internet info only, hopefully someone who's actually seen the poison plants and been able to identify them with 100% accuracy will confirm. It seems the gardener you've employed is either unable to recognise them, or is hoping to charge more for dealing with 'poison plants'.
http://www.teclabsinc.com/tips-info/images-video/images/poison-plant-identification/
I live in up-state N.Y.. The 5 leaved plants in the fore-ground look like the same stuff I have growing up one of our trees. It also trails along the ground. A couple yrs. ago I tried pulling it up, got itchy blisters on my hands and feet.. either p. ivy or oak..IF it's one of those, check and see if it's running along the ground. If you do the newer leaves are almost reddish, and be careful.
Donna White
  • 424
