Spring has sprung and it's time to turn on my reticulation (bore).
My retic worked back in May but now (October) I turn it on and no water comes out.
I can hear the pump going but no water comes out. Any ideas? I only ran it for a couple of minutes because I heard you can blow up the pump if there's too much pressure. Do I have to let it run for a while to fill up the pipes?
J. Musser
  • 52,241
  • 122
  • 333
Coomie
  • 2,914
I had the same problem sometime back; it finally turned out to be that the pump pipe has air sucked in, which creates reverse pressure and so the water could not be drawn/sucked.
If your pump is accessible you can follow the steps below to remove the air:
  1. Search for a small cylindrical metal cap on the top of your pump. This cap can be opened/closed just like a bottle cap with hands.
  2. Open the cap with hand or pliers and pour some water into it, around a glass full. Then close the cap.
  3. Turn on your pump and wait for a minute. If the problem was with air in the pipe it should start working immediately.
Try it out, and see if that works.
  • 7,289
  • 81
A_garden
  • 59
