I had a potted aloe plant that looked like a set of leaves coming out of a single spot at ground level. One day it just fell apart - the leaves and the roots got completely rotten at ground level and wouldn't hold leaves together and to the ground. Leaves otherwise look alive - they are just damaged at the end where they were connected to the root.
According to this answer aloe plant leaves can be planted on their own and can perhaps start growing as separate plants. Will that technique likely work in my rotten case? Do I have any other options?
sharptooth
  • 1,685
  • 25
If your leaves have rotted at the base, there is nothing practical you can do to save the plant. The leaves, though you can sometimes root them, would probably do poorly because they are not fresh. The best thing to do would be to find out what caused the rot, buy a new plant, and carefully monitor it so that you can fight the rot as soon as it appears.
winwaed
  • 20,513
  • 65
  • 118
J. Musser
  • 52,241
  • 122
  • 333
