I have a Japanese Knotweed problem in a limited area (about 15x15 feet).
It is very difficult to dig up the roots because they can be a good 2 feet underground.
Therefore I am considering death by injection: cutting off the stalks about 6 inches above the ground and pouring imazapyr into the well of the stalk. Will this be effective? Is there a better approach?
One pamphlet I read described an experiment where they did something similar but used a mixture of glyphosate, triclopyr, and imazapyr. I am not really expert in different herbicides, so I am looking for some expert advice here.
Andre Lenotre
  • 945
The usual method is to pour glyphosate down the hollow stalks,not sure how well the one you mention will do. Repeat and ongoing treatments are necessary,but one other thing - if you're going to cut down any of this plant, don't compost it, don't carry it anywhere without bagging it up first, and if you can, burn it, if not, where you are, it should be possible to put it out with the trash. In fact, its probably safest to put each stalk you cut off straight into a bag rather than laying it on the ground till you have a collection, then bagging it. The tiniest fragment of this plant inadvertently dropped on the ground will grow. And, by the way, the roots actually go down 9 feet... information here re various treatments tried in your area,along with a note at the bottom about being able to bag it up and put it out with the trash
https://www.cctvcambridge.org/Japanese_knotweed_Harvard_MIT
This is the follow up, four years later. I have pretty much extirpated the knotweed. There are are a few plants left, but they have been targeted for termination.
The imazapyr is an incredibly powerful herbicide. A single drop of it will kill any plant it happens to fall on. The main problem I found with injection is that the stalks of the plant are pretty tough, so you have to search around to find a place where you can get the needle into the pith. One constant problem was that pith can jam the needle. I used up a lot of needles during the operation.
There was some pretty heavy collateral damage. Two mature trees were killed during the operation. They were about 10-15 feet away from the stand of knotweed, but I guess their roots must have been in that area. Even though the herbicide was delivered specifically to each individual knotweed plant, someway or other the herbicide must have been transported to the roots of the trees, thereby killing them.
The Imazapyr does get down into the root system of the knotweed because re-growth has been very restrained.
The whole area where the knotweed was is kind of a wasteland now, with just a few weeds growing on it. I will probably have to re-sod it, or probably just build a shed there.
Andre Lenotre
  • 945
All photosynthetic plants need light to make their food. If light or photosynthesis is denied, either by continually cutting off new growth or burying very deeply and combining the cutting of any green growth any plant will die. This exotic 'weed' is one of the top most prodigious of all, only surpassed by purple loose strife and that European Birch, Paper?! All those chemicals would only make everything worse. Would not help at all. I am a licensed commercial pesticide operator, supervisor and I know that it is far easier to not use pesticide and learn how to garden correctly as to prevent having to use bandaids for unnecessary mistakes. I allowed our electric company who were in the process clearing electrical lines to dump their chips over this huge area of blackberries 6' deep. Caused this cool fog all winter long from the heat and by the spring 6 feet ended up 6" deep and not a single blackberry ever came back. For Equisetum we routinely weed wacked the green growth and after 2 years the Horse Tail was gone. I've tried chemicals from time to time but I am serious, they aren't worth the trouble.
stormy
  • 40,664
  • 76
