I air layered this ficus. I think it is a microcarpa. Its an s-type they sell in nurseries. I am using it to make lots of smaller trees.
The image shows the roots that have developed. I would like to know if this is ready to be cut and potted or shall I leave it for longer?
JonathanC
  • 695
I'm not sure is the answer - air layering is usually done on smaller branches with green leaves present, not on a large and woody main trunk. Ficus bleed profusely when cut, so bleeding from such a large area (once cut below the new roots) may be so excessive the plant doesn't cope, and that applies to both halves. I'm also pretty sure that the new roots formed (even if there were twice as many) will not be enough to support such a large amount of trunk and topgrowth once severed. It would have been better to air layer one or two of the upper branches instead, quite honestly.
Info here about the method and choice of growth to air layer
https://www.rhs.org.uk/advice/profile?PID=405
A couple of weeks later, I cut the trunk and potted in a mix of vermaculate/organic potting mix.
Here are both bottom and top. I have started a new layer on the top piece.
Last time, I did not use any rooting hormone, this time I have.
The original question was whether I should leave it for longer. I can partially answer it. I waited 10 days more and the cut it. 2 weeks later new growth is occuring on both plants and its looking healthy..
JonathanC
  • 695
