16
I got one of these snazzy paper pot makers and made a ton of pots to grow all sorts of stuff. It's pretty cool because, unlike a bedpost, you can press the newspaper you use to make the pot into a little form and it stays that way, just like a real pot. I put a little bit of masking tape on them just to keep it together until I filled them with dirt.
What should you do with the pot when you plant it to make sure the seedling had the optimum chance of growing and the roots take... root in the soil?
  • 7,289
  • 81
Peter Turner
  • 9,211
  • 40
  • 83
If it is just a paper pot, I would suggest that you plant it along with the paper. Paper disintegrates very easily and within a couple of watering cycles, most of it will have become mushy and the roots won't have any trouble in growing right through it. Also, by not disturbing the contents, it is less of a "shock" for the plant.
Lorem Ipsum
  • 11,219
  • 58
  • 95
If you make the pots out of newspaper (black & white only is the best -- definitely not glossy/coated), and the plants aren't overgrown, then just plant the pots in the ground. Newsprint will rot away quickly.
If the plants are large (starting to become root bound in the pots), it wouldn't hurt to slash the paper a bit when planting so that the roots don't have to do any work to push through the paper.
I haven't used paper pots, but I'm guessing that with the watering you do during seed germination and the first few weeks of growing the paper will be well on the way to disintegrating away by the time you get around to transplanting.
The advantage of paper pots versus plastic pots is that you don't have to remove the seedlings to transplant. This avoids root disturbance which sets back seedlings after transplanting. I suspect the advantage of paper over peat is that paper pots will rot much faster than peat pots (I've seen peat pots persist quite a while after transplanting, especially if the pot isn't slashed up when the transplanting is done).
bstpierre
  • 41,932
  • 118
  • 240
In addition to keeping any sprouts wet while waiting to plant, you should thoroughly saturate the pot itself just prior to putting in the ground. It is also recommended that you "tear away the bottom half of the pot before placing the plant in its hole to exposes some roots to direct contact with the soil.(source)" On the latter step I am not 100% sure it applies to all scenarios, but on the former step I have heard and seen (on manufacturer's packaging in particular) this advice repetitively.
mfg
  • 2,332
