15
I'm wondering if it's okay to use water that has drained through a houseplant to water another plant. Is it safe for both the other plant and the soil? What I mean is that we use at least 500ml (2 cups) of water for each pot on an average basis. A lot of the water is drained from the pot, so if someone has no trouble collecting the drained water, can it be re-used to water another houseplant?
This might seem nonsensical, but consider this when you have to water 30-40 or more plants. What one will achieve via this is conservation of water.
4-K
  • 3,217
  • 48
  • 68
5 Answers5
Well, the correct way to conserve water is to watch your water, and make sure you don't have excess drainage. This of course takes time and experience. Till then, use measuring cups, or watering jugs that have measurements on them. Or, if watering with a hose, time yourself. A kitchen timer for example, can come in handy.
Unless you have different soils for different plants, such as citrous fruits etc., you can do this. Collect the excess water, dilute it with fresh water, just in case you have used different or excess fertilizer on a plant etc. and then re-use it.
Still, given the possibility of diseases etc., I am a bit uncomfortable with this approach.
Srihari Yamanoor
  • 3,636
I haven't found any good reference sources, so this is just my personal experience. It ended up being too long for a comment, so I hope it's appropriate as an answer.
I do this frequently, with both my indoor and outdoor potted plants. Especially outdoors, I tend to be lazy, so if I've already put away the hose or watering can, and notice something overflowing, I just pour it into a nearby pot. As Srihari Yamanoor recommended, I do make sure the potting soil is exactly the same.
It didn't occur to me until just now that some plants may deposit things into the water that aren't good for a different type of plant, so maybe in order to be safe rather than sorry, you should only use the same variety. In my experience, though, it hasn't mattered. In fact, more often than not, my second plant is a different species altogether.
Again, as with Srihari Yamanoor, I have a concern for bacteria and insect growth. For that reason I never let the water from the original plant get stagnant. Although there are some plants that will re-absorb it, some won't, so I take that into consideration when water drains through the pot into the saucer below.
If I know the original plant won't use it quickly, or if I've overwatered to the point where it's spilling out of the saucer, I collect it and quickly use it to water another plant. I've never diluted with fresh water, but it sounds like a good idea.
Unless you are OCD about water, which might come in handy someday, watering your potted plants who depend on you completely means giving them the best chances for survival; the best soil, the best water, (learning how to water, watering with bottled, well or filtered water), how to fertilize, the proper fertilizers (less is best), light, air movement, how to assist your plant with pruning...
I would not use water that has drained out of a pot, from a saucer on a REGULAR basis to save on water. Once in a while is fine but the fertilizers, any water borne disease and salts built up from tap waters will be condensed and the type of soil, even potting soil which usually has lots of peat moss can make the water too acidic for other plants. Heavens if one is using garden soil in their pots! Pure plain old water is the only thing I will give my potted plants.
stormy
  • 40,664
  • 76
Uh, yes. it's just water. Dirty water but water none the less. Many planting systems use cascade feeders to mitigate overwatering.
LazyReader
  • 782
Whatever you do, dont take the drainage and circulate it back into the clean resevoir... I did this and worked well, till I used a liquid organic fertilizer and it started to stick. I am debating sending the water in another way... can't imagine dirty water being inherently bad for plants, even if it had rotting corpses in it with gonarea-herpa-siphalaid... nothing in this world more dirty than dirt, and plants live in it.
gunslingor
  • 101
