35
I've got what I think is a cedar tree in my backyard that is missing most of its bark on one side from the ground to about 4' up. (Thanks to my puppy who is a shredding machine.) The branches next to the bare area of the trunk are slowly turning brown and dying. Is there any way to revive the tree and minimize the damage? Should I prune off branches that appear to be mostly dead?
Also, on the topic of preventative action: Are there products that successfully keep animals (dogs in my case) away from trees and shrubs?
Lorem Ipsum
  • 11,219
  • 58
  • 95
Doresoom
  • 2,562
  • 25
Tree tubes can protect trees. They're mostly aimed at protecting young saplings from deer.
Protective schemes to protect more mature trees from beavers can be more extreme.
Tangurena
  • 2,083
Depending on how its root structure is doing, you may be out of luck. It is late in the season to be pruning trees back. For now, protect the tree (tie a bit of carpet around it at the heights the dog can get to) and keep it well watered.
As for keeping the dog away, you might ask on the pet website, but for a dog you own, you will need to do on-the-spot training. Let him go for the tree, then explain that it is YOUR property and he is not allowed near it. Do this a few dozen times...
Alex Feinman
  • 1,272
Bridge grafting may be the technique you're looking for. This method uses smaller stems to bridge the gap, allowing sap to flow across.
Tree saved from girdling by bridge grafting
Image credit found here, with directions on how to use this technique.
John Walthour
  • 1,028
