I'm planning a home growing system combining aquaponics and aeroponics and am trying to understand if I can find another use of the aquaponic water setup and specifically for aeroponic systems with either misters or sprinklers.
Do you have experience with such hybrid systems?
Thanks in advance!
kr3t3n
  • 335
The problem with using aquaponic water is that it is full of solids and fines. These have to be filtered out otherwise your emitters are going to rapidly block up. If you can filter it, I don't see an issue for using aquaponic water for an aeroponic system.
Graham Chiu
  • 23,509
  • 96
I am using the aquaponics system nutrients water in a vertical grow tower by supplying the nutrient water by pump. The water drips from top of the tower along inside walls and taken up by the plant roots. I have grown the largest heads of lettuce and chives , compared with gravel bed and deep water culture DWC. Really pleased with this method
I am considering this too. The problem as I see it is that the aquaponic water has ammonia in it, with normal aquponics this is then converted into nitrates ie plant food by the bacteria in the system. Normally the bacteria live on the clay pellets I think. With aeropnics where do the bacteria live ? Normally an aeroponically grown plant is in a basket with not medium to sit in, its not an issue here since the water has the plant food included. In your proposed system I'm not sure how the ammonia would get converted.
I think some kind of medium would be required, but not sure on the best way to set this up. I guess clay pellets in the basket might work. Something to experiment with and see if you get the results you want.
My view is a tad different to others. Plants with aerial roots service with the roots being in the air. They do not expect or rely on fertilizer being sprayed on them.
I suspect that both water and the nutrients in it will probably damage your aeroponics. The suggestion here is to have a very weak solution sprayed just on the roots for a very short period of time.
Feeding
Aeroponic systems have a unique way of feeding plants. Small nozzles, like tiny sprinkler heads, produce a mist for a brief period every 10 or 15 minutes, 24 hours a day. The nutrient solution mist covers the roots of the plants, where it clings long enough for some of the nutrients to be absorbed. As the liquid drips off, the roots get a chance to take in oxygen, which they also need, until it’s time for the next round of spray.
From Aeroponics & Feeding Your Plants
There's a similar suggestion here
How Aeroponics Works
The Aeroponics system utilizes a sprinkling method of feeding plants and plant roots are suspended in the air.
The system has small nozzles which are made up of tiny sprinkler heads. This generates the mist for a short period. Set the sprinkler to sprinkle nutrient solution every 10 or 15 minutes per day. This misting will engulf the plant roots where it hangs long enough for some of this nutrient to be assimilated.
Once the mist stops, some of the nutrient solutions drip off to give the plant root a chance to receive oxygen. So they use this brief moment to take in oxygen until the next round of misting continues.
From Aeroponics Nutrient Solution Recipe
Rohit Gupta
  • 3,203
