14
My name's Chuck, and I'm a plant.
Chuck
Bamboo tells me I'm a Sansevieria trifasciata laurentii, also known as "Mother in Law's Tongue" or "Snake Plant" (see other question here).
I live indoor with my human flatmate.
I think I may have some health trouble.
The ends of my leaves are turning brown, and so does the whole leaf on occasion (there's one in the picture).
I also noticed my roots are kind of sticking out of the pot a bit...
I am exposed to only electrical light, and average apartment temperature.
There's no way for me to go play outside, as it's freezing and raining all the time out there.
Questions
  • Is the human not giving me enough water, or maybe too much?
  • Should he move me to a larger pot or am I ok as is?
  • Are my looks ok, considering I'm indoors all the time?
  • When one of my leaves turns entirely brown, should the human cut it out or just leave it there?
Bence Kaulics
  • 1,948
Mena
  • 307
First, I missed off a bit of this particular one's proper name - it's Sansevieria trifasciata laurentii; the version without yellow stripes is just Sansevieria trifasciata.
My houseplant book says to only re-pot when the pot it's in starts to bulge - then you can either pot into something larger or divide the plant in two and pot the sections separately.
My book also says that sometimes, Sansevieria has a disorder which causes leaves to brown and die - the trouble begins at the tip of the leaf and works its way down, which might be what you're describing. The cause isn't known and there's no cure, although if a plant is overcrowded in its pot,that can be a cause of this problem.
Doesn't look as if yours is desperate for re-potting or division though - information here on how to deal with dead leaves and on re-potting/division - note that it says you can make leaf cuttings to start new plants, but be aware that propagating it in this way will produce an all green plant, without the yellow stripes you currently have.
Watering - Snake plants like things on the drier side. I know it might pain you to leave Chuck alone for so long, but he should be watered like a succulent. Let the soil go dry a half inch down (at least) before watering. When you water, as soon as it's dripping out the bottom, you're done.
Roots - Chuck is fine being root bound. Repot every 1-2 years, and either upgrade his living space or prune his roots. For root pruning, watch a couple bonsai root pruning vids BC there's a good amount to learn and those techniques work for ant plant you're not trying to propagate.
Light - if you want Chuck to be happier, head to the hardware store and pick up a ballast ($8 or so, should have a clamp), an LED bulb 60w equivalent with color temp 5000K or 6500K (spotlight bulb is better but a little pricier), and an outlet timer. Set the bulb to 13-14 hours/day. Bulb can be a few feet from Chuck. Closer is better, but you want the light hitting Chuck all over. I'd set it so it's at a 60 degree angle, at a distance where it's hitting him from soil to tip, then rotate Chuck 90 degrees every 2 weeks.
When it comes time to repot him, use a terracotta pot and succulent/cactus soil. (I'd use coir with a lot of perlite and pine bark fines mixed in.)
For feeding, I recommend Osmocote plus at half strength. (Bearing in mind that it's directions say half strength for indoor plants - so Chuck would get 1/4 strength compared to an outdoor plant.)
Don't worry too much about the leaf tips. It's likely an effect of the combo of less light and altered watering schedule.
Remember - overwatering is the real killer.
If you just bought Chuck (which from his roots I suspect), repot him. He's been in there for a long time.
Paul Nardini
  • 2,183
