17
This harvest I was not able to pick a single corn cob. Some large animal(s), I suspect raccoons, got to them before they were ripe (I would find peeled and gnawed corn littering the lawn and the corn stems bent down when I got home). I had crushed garlic all over the garden. This kept the rabbits away, but was not effective against the large animal.
I am looking for a solution that does not involve putting a fence around my garden patch. Are there plants that raccoons are repelled by? Has someone tried prickly plants to make the patch unattrative to raccoons? I am told these are very intelligent animals, so I think the solution will have to be a mix of good ideas.
Lorem Ipsum
  • 11,219
  • 58
  • 95
Om Patange
  • 2,928
10 Answers10
13
When the corn is about 1-2 weeks from being ready for human consumption put a battery powered radio tuned to an all night talk radio station in your corn patch. Music does not work. The raccoons will avoid the "humans" for a while. You have to time this carefully to your corn crop because after a couple of weeks the 'coons will figure that those voices they hear are not really people. You have to have your corn harvested before then.
Rodney Schuler
  • 1,216
My solution for large omnivorous varmint problems (opossums and skunks, here) is a Havahart trap. I release them far from anyone's home, a few miles away. I've gotten rid of over a half-dozen opossums and a half-dozen skunks with it.
You need to use bait that's specific to what you're trying to catch. You don't want to catch Fluffy from next door. For racoons, marshmallows are a good choice - except that skunks like them too. I can explain how to deal with skunks if needed.
The nice thing about this solution is that it's semi-permanent - till the next varmint moves in.
Ed Staub
  • 6,459
I don't have direct experience with raccoons, but these are techniques I've heard about:
  • Surround your corn by pumpkins / winter squash. Raccoons do not like the spines from the squash vines on their feet and will not cross the barrier to get to your corn.
  • You said you don't want to put up a fence, but you might consider a couple of strands of electric fence. One strand at 6", one at 12". Connect this to a fence charger like you'd use for cows or horses; solar-powered chargers (and the fencing) can be found at your local feed store / Agway. There are also temporary "push in" posts that you can attach the fence wires to. You could set it up for just a couple of months in the summer while your garden is at risk from marauding raccoons.
  • A motion-activated strobe light / noise maker. As @rschuler mentions, they may get used to this after a couple of weeks so you have to time it carefully. You may also get better effectiveness by moving the strobe a little bit each night so that they do not become accustomed to it as quickly.
bstpierre
  • 41,932
  • 118
  • 240
One of my favorite methods is to lay strips of aluminum foil around the entrance to the garden or around the plant. When stepped on, it scares off the animals. I also plant hot peppers, marigolds, and sprinkle cayenne pepper. I'm not letting then win!
  • 7,289
  • 81
sandy
My house once had a piece of clear tape/plastic/paperish-like material dangling from the eaves. At night, even a light breeze would rustle it, and it sounded just like an animal moving through some bushes. It scared our neighbor's cat away, anyway (quite funny to watch), and I didn't even know what it was the first few days or so I heard it. Even after I knew what it was, I still wasn't always sure it was it making the sound. It makes you feel like something's going to pop out of the bushes and get you or something. Something like that might scare raccoons and opossums, too. Even if they figure out what it is, it might still make them nervous, since things rustling in the bushes sound the same.
Anyway, I don't know what material that was, but it was involved in repairs to the guttering of our eaves or some such. I think it was about eight inches of the material hanging down. It had the width of packaging tape, but it probably wasn't sticky.
Brōtsyorfuzthrāx
  • 18,694
  • 70
Buy habanero sauce and spray the corn with a solution of water and hot sauce. Bait a few corn cobs with full strength sauce, then pull the corn husks back up and lay them where the raccoons enter the garden.
  • 7,289
  • 81
if you can safely fire a shot gun do so around the garden and leave the shells, it will keep the critters away. or any type of ground fire works that has gun powder and leave the residue will also work. we did this and went from no corn to 40 bushels.
vt farmer
Trap them with cages, shoot them when you trap them. Throw their carcasses out where your woods are as a warning to all that try and mess with your corn crop. Racoons are not an endangered species and you will save yourself from further problems by their young next year.
Matt
All you need is a spotlight and a pellet gun. Once you put the light on them walk up with the light still on them and then shoot them. Once they are dead cut there neck and make them bleed and walk all around the garden... This will alert all the other coons and they will not come back
user8558
You have never owned a really good pellet gun. I have one almost as powerful as a 22 rifle. Have killed many raccoons with it. Quiet and deadly. Problem solved.
