I noticed about 4 days ago that leaves on one of my peppers got soft and started to hang down a little. I thought that it just needs some water so i watered it along with my 2 other peppers. Today the same pepper looks like it again needs more water, while the other 2 are in pretty much good shape. I inspected the plant and found out that a lot of leaves from its top half are completely dry and basically dead. The rest of them is either normal (young and small leaves look the best) or seems to be attacked by an insect (or a disease?) i can't identify by myself.
Attacked leaves can have small dry areas and strange little spots on them (maybe eggs of an insect): enter image description here
And others look like they have been bitten (backlight for better visibility): enter image description here
I have also noticed one tiny white/yellow bug walking on the plant. I couldn't take a clear picture of it, because it was to small.
Are these symptoms caused by an insect or is it a disease?
If it is an insect, how can i get rid of it?
Are my other plants in danger?
Michał Górecki
  • 301
5 Answers5
I checked both options provided by cr0 and Alina (Thank you both very very much). During the process of comparing the symptoms of glasshouse whitefly and spider mites to my plant's situation i stumbled upon something that i belive matches the damage done to the pepper more than both of the previously mentioned insects - thrips.
Here are the reasons why i think that:
  • Images shown in this article (images labeled - Thrips on Peas) closely match, how the attacked leaves look. Black dots of excrement pinpointed on the first thrips related image of the article are visible on my first posted image.
  • In the article it is also mentioned that the trips leave some kind of shiny cast on the plant after feeding on it and the damaged areas on my pepper really do shine.
  • The greenhouse whitefly didn't look quite like the insect i spotted, but the two thrips shown on the second image from the article look pretty much like the bug which i tried to describe in my question (sorry, i should have given a little bit more detailed description).
  • Spider mites looked like something close to that, what is attacking my plant. There even were some single web strings hanging around the peppers, but nothing as dense and as small as the spider mites webs shown on images related to mites. I know it can still be them, but the webs look more spider-like (regular spider not spider mite) to me and there was in fact a little spider, which could make these webs, hanging around my desk a little while ago. At least i hope it was a spider and not a spider mite.
I'll now try to get rid of the insects treating them as they would in fact be thrips. If i succeed i will assume that i was really dealing with thrips and accept this answer.
Michał Górecki
  • 301
That looks like spider mites to me. They break into plant cells to eat, causing a dried out or deflated appearance in plants, and they hang out, spin webs, and lay eggs generally under the leafs as you photographed. They're pretty common among indoor plants in my experience.
There are different tricks for dealing with these pests. You can read more about countermeasures to spider mites online, such as in that Wikipedia article I linked to where it mentions using Neem oil:
Neem oil may provide control, when combined with a suitable surfactant and diluted with water. As with chemical control, repeated applications are required.
I know of many people who use Neem oil as a countermeasure. I just mist the plants with water frequently and that helps, and if it's really bad, I use slightly-soapy water to mist or rinse the leafs. In really bad cases, rinsing the leafs with soapy water then with fresh water and wiping the underside of the leafs gently can remove the mites. Sometimes that does the trick, sometimes the mites return.
Your other plants could be in danger of these pests too. Try to isolate the infested plant and keep it isolated for a little while after getting rid of the pests to ensure they don't spread to other plants.
cr0
  • 2,047
The yellow and white insect is Trialeurodes vaporariorum. To prevent infestation, plant traps can be used (plants that attract it and leave alone most part of your other crops), but it's too late now. The best way to get rid of adults is a systemic insecticide, like Actara and Mospilan. Go to the nearest shop for pest control and ask for alternative insecticides against greenhouse whitefly if those are not available.
Remember to use the insecticide in the concentration stated on the label. Too little will be ineffective, too much might create resistant superbugs if a few of them escape. If your neighbours use one insecticide, buy the other one because the insects might be already resistant. You may have to apply when a new generation of insects become adults, usually every 3 weeks.
The best way to kill the eggs is using horticultural oils. If you don't eliminate the bugs, they will expand to your other plants.
The brown areas on the margin of the leaves are caused by something else, I don't know what.
Alina
  • 5,484
  • 49
Sounds as if you are over watering your peppers. Do not water until those pots when lifted feel very light!
stormy
  • 40,664
  • 76
I think the insect's damage your plants is thrips. This information can help you to get rid out of thrips
