I have a long tough box on my window which I stuck some root ginger in. The ginger was in my fridge and sprouting so I figured I'd see what happened. Fast forward a few years and it's a huge clump of root and a lot of it is above the soil level and pushing on the edge of the box. Clearly, I need to do something. In my head, I call it "re-seating" because that's what I'd do with PC RAM if it was not sitting right.
Anyway, the ginger is sprouting at the moment and I have three good stems already. Is this a bad time to re-seat the ginger? If so (and my guess is that this is a bad time) when is the soonest I can harvest and replant for least damage and best grow back?
Edit: (For clarity) This is a window box inside in my flat on the window. It is currently sprouting and bunched up and needs to be better planted soonish.
Hmm, well, your ginger should have been harvested a few months back, as the leaves died down - at the time when you harvest the root, you can keep a section which has incipient buds or eyes for replanting to grow the following year. Frankly, I don't know what will happen if you dig it up, cut some of the root off, then replant, depends what you find when you take it out of its container. It's not a question of 'reseating' by the sound of it, because it sounds as if the roots are now so extensive, there's insufficient room for them in the container, though a photograph of it would be helpful.
You could perhaps risk unpotting it and having a look at where the growth is coming from, slicing off parts which don't have growth and replanting the part that does, but again, its difficult to say without seeing it. Otherwise, it means waiting until the plant dies down, then harvesting the root, keeping a section with eyes and replanting that. Of course, you could always just harvest all the roots and buy another piece of ginger from the supermarket, plant that in your box with fresh potting soil, and let that grow.
Since ginger forms rhizomes, I'd simply get a large sharp knife (one you don't mind being used like this) and cut through the branched rhizomes. Leave the large pieces with the new shoots in the soil mix and remove (harvest) the rest. The fibrous roots attached to the rhizomes with shoots will provide for the shoots and as the shoots open to leaves, they'll nourish the rhizomes and new off-sets will grow. I've done similarly with other plants with rhizomes - bearded irises, for example.
It might set it back a little but I don't imagine that much. Certainly, it would bounce back faster than planting bew hinger. To ensure the cut surfaces of the rhizomes remaining in the soil don't rot or get pathogens entering, water it and then clear soil away from the parts you cut through only so they can dry and form a callus. Should form a callus within a week if you keep it dry. You can then cover it with soil.
Jude
  • 1,626
