18
We know that urine can do a plant good. Certain plants (like citrus trees) will absolutely do well if you add urine to their intake.
But urine is very high in nitrogen and could potentially "burn" the plant. What are some common plants/trees that can flourish with urine as a fertilizer? Is there some way to tell which ones to avoid, lest they shrivel up and choke on the nitrogen?
nikulabs
Eight Days of Malaise
  • 1,409
Urine is very high in nitrogen. One can observe how plants handle the quantities humans would produce by observing the yards of people with large dogs. Plants usually get "burned" from the quantity of nitrogen deposited by the dogs.
If your compost heap has a lot of straw/cellulose, then it probably needs more nitrogen. If you want to use your own stuff to fertilize plants, mix it about 50% with water in a bucket (or watering can) then apply it to plants. Fill the bucket/watering can indoors, and wash it out afterwards.
Lorem Ipsum
  • 11,219
  • 58
  • 95
Tangurena
  • 2,083
My Tomato plants get watered with urine 3 times per day. They thrive! This urine is not diluted - it coms from my night bucket; where a lot of water has evaporated;
Rohit Gupta
  • 3,203
Any. Urine can be used as a fertilizer, however it should be watered down before application to prevent oversaturation of ionic minerals (sodium).
LazyReader
  • 782
