Over the years I have seen examples of people making a type of compost tea which is made by using a large barrel filled with about 70 - 80% water and then adding all sorts of stuff.
Some examples I have seen:
  • Dead cane toads -> Just found video here
  • Grass clippings
  • Seaweed
  • Chicken manure
  • Meat scraps
Note, these examples I have seen both on television and in practice.
The mixture is left to decompose until it is mostly liquid (there is no separation of ingredients and the liquid) then it is further diluted and applied to the soil.
From the results I've seen in the real world I want to start making the same stuff but I want to know what I should avoid putting in the mix; what should I not put in this tea if I want to avoid making my family sick?
J. Musser
  • 52,241
  • 122
  • 333
going
  • 6,412
  • 37
  • 64
I've had a look around the interwebs and it seems like you can make compost tea with just about anything. It will grow some nasty pathogenes, but if your tea is brewed properly (oxygen rich with decomposed compost) they should be at a safe level. Here are some things to remember:
  • Avoid getting compost tea on foliage - those microbes only work on soil.
  • Wash your vegetables - you should be doing this anyway, right?
  • Don't eat dirt or drink compost tea - duh!
This quote sums it all up pretty well:
Soil itself has about 10 billion microbes per gram, and they're pretty much the same microbes that are in your compost pile. Avoid eating compost just like you avoid eating dirt and you'll be fine.
Here are some links:
http://www.soilfoodweb.com.au/index.php?option=com_content&view=article&id=78&Itemid=56
http://heartgarden.com.au/composttea.asp
http://forums2.gardenweb.com/forums/load/soil/msg0700020013496.html
Coomie
  • 2,914
Compost should be fed an organic, vegan diet. Adding meat/biproducts to your compost pile can attract bad bacteria/insects that will have negative effects on your tea
