My crabapple tree is having a hard time. It's fighting Japanese beetles, spider mites and now this "thing" on some leaves. It starts by creating a red spot on the leaf and eventually there's some "thingies" that pops out.
Does anyone know what it is and how to get rid of it? I live in Québec, Canada.
Leaf with sickness Other side with sickness
Sorry, my gardening vocabulary is fairly limited! :)
Alina
  • 5,484
  • 49
Maxime Morin
  • 305
Cedar-Apple Rust
This National Gardening Association report has good information about the problem. This is from part of that report.
The first symptoms on apples are pale yellow spots on the upper surfaces of the leaves and on developing fruits in mid to late spring.
The spots gradually get bigger and turn orange or red, and you may see black dots in the upper surface of the spots. In mid to late summer, if you turn the infected leaves over, you'll see tiny tubes growing out of the spots.
The ends of these tubes split open and curl back, releasing spores into the air.
Anglian Bonsai
  • 337
In addition to the information here Found on a Red Cedar. What is it?, if you have any Red Cedar (Juniper) trees on your property, check them over - if you see evidence of this infection on them (and you will) clip out the affected parts now, as it says in the answer. There is no other treatment available.
Unfortunately, if there are other Red Cedars in the vicinity which are not on your property, meaning you are not able to cut them in any way, you cannot interrupt the life cycle of this particular gymnosporangium infection; I'm afraid that means your crab apple will continue to have the problem ongoing. If this is the case and you decide to remove the tree because it's unsightly, the presence of this infection in the neighbourhood precludes planting any other tree in the Rosacaea family, which includes apples, crabapples, hawthorn and others, for they will suffer the same fate.
Yes its rust, best thing to do is remove the tree entirely including the stump as it will reshoot from the base and those bits will be infected too- the fungus is systemic and has infected every part of the tree, burn all affected parts, don't compost or bury any bit too, plus its often another plant is also infected too, so do a hunt around your garden and remove that plant too, often the other plants are unrelated to the main one. clean up all dead leaves in the entire garden- as the wind will spread this about- fungicides are all but useless on this problem as once spotted its often too late. sorry for the bad news.
olantigh
  • 2,252
