My 3 year old peace lily has been in this clear pot for almost a year and within the last few weeks these spots began appearing near the roots and now cover the soil on the top layer. The spots are in clusters and are greenish-white.
The peace lily blooms regularly and seems to be fine in terms of its leaves.
I took it outside for the first time since I repotted it a few weeks ago, around the time this started happening. I live in Brooklyn, could it be something in the air?
Can anyone identify what's causing this and how bad it may be?
Alina
  • 5,484
  • 49
JLF
  • 163
You've got eggs! I am checking on what insect this could be but I've also got two questions; does this pot have a drain hole? and second, is this soil from out of doors or is it potting soil. The timing of transplanting and being out of doors a few weeks ago is telling us that something really liked your plant's soil. If you transplanted using your own garden soil/compost that isn't sterilized you included an insect into your mini ecosystem.
I'll go find some good candidates. If I were you, I'd get a similar sized clay pot with drainage holes and plain potting soil to transplant your plant again. No fertilizer or water holding sponges/gels added to that soil. You won't be able to remove all eggs so don't worry about that for now. I'd keep some of that soil and eggs in a container all by themselves to check out what hatches!
Here is an initial culprit; Oak Lecanium Scale eggs of Oak Lecanium Scale
When you transplant with fresh bagged sterilized potting soil, clean off all dead leaves and debris from the top of your plants. If you are using potting soil then some errant insect found your peace lily and deposited eggs while out of doors. Should not be a problem at all for your lily. btw, do you own a cat?
scale eggs and predators
stormy
  • 40,664
  • 76
