I have some blackberries and red raspberries, and I'm not sure how to winter-prep them. After pruning (which I'm skipping this year, since the primocane raspberries are only in their first year), how should I mulch them?
Should I take them down from the trellis and lay them flat on the ground, and pile straw, leaves, and woodchips on them by about an inch?
I'm in USDA zone 6a.
And if I get cow manure, should I put it under the mulch? Likely I won't get cow manure until spring. I don't have compost.
Do I also need to add mouse-traps/rat-traps around to kill rats as some suggest? Will the rats damage the plants? If not, the plants are far enough from my house that I don't care if the mice are there. Are poison traps alright (the bait stations with solid blocks they munch on), despite it being near plants I care about?
VividD
  • 5,870
  • 74
Jamin Grey
  • 855
I am zone USDA zone 3 b to 4 and you can't kill blackberry plants. I have mine growing with morning sun in a raised bed beside a concrete foundation. Every year, dead to the ground, every year eight to nine feet tall in the autumn. Don't bother with any extra work, cut them back to the ground in the fall and stand back in the spring.
I do top dress with shredded leaves every fall but otherwise there is no pampering. These plants don't need it.
kevinskio
  • 62,221
  • 167
I never mulched reds, yellows or blacks in the Chicago area. The only problem was the rabbits ate them when there was snow cover on the ground.
blacksmith37
  • 8,892
I discourage the idea.
The moment a cane's tip touches the ground, the plant is seriously tempted to grow roots. Plus, the canes bend easily while young, once they mature, they tend to break or get otherwise damaged. So while you can easily bend them down now, it might be not so easy to get them bach up again.
Note that many gardeners see at least their wild ancestors as weeds - they are really robust and hard to eradicate. Even if they freeze to the ground, they will push out new canes in spring. So no need to pamper them.
You can of course mulch them and they will also like some fertilizer, but don't overdo it - you want to encourage flowering and fruiting, not just more and more canes.
I suggest you bite the bullet and read about proper pruning. Especially if you had only few fruit this year. The "spent" canes should be removed to encourage the plants to "push" their energy into the new growth.
Stephie
  • 17,295
  • 61
