Please see pics below. I'm assuming (possibly shouldn't assume) that this succulent was in poor light before I brought it home because of all the spreading. What's the proper thing to do with it? I'm wanting to re-pot it because the pot can't stand on it's own, without putting something under each of the two main spreads. All clippings and pups are rooted in, and when I went to remove, to re-pot everything came out in one chunk. Is it safe to clip the roots, or will the plant suffer? When I re-pot it, should they all be separated, or should I put it in a pot wide enough that the spreads are also touching soil, so they can root down?
Top View, full plant
Side view left spread
Side view right spread
close up of pup roots
Close up of additional pups
UPDATE: Voila! What do you think? (PIC BELOW) I don't like answering my own questions, and received much help from @Bamboo comments. I've included a pic of what I did with it from the advice. I layered the bottom of this pot with large aquarium gravel then topped off with my own mixed: mixed bird grit, playground sand, cactus soil and regular potting soil together. I potted the "clump" from old pot and filled loosely with the mix. The spreads are gently resting on top of the soil mix, and I lightly sprinkled some of the mix on top of the exposed roots. I only lost 2 roots, and one leaf (clipping shown in right bottom corner), that I placed on top of the soil. This pot has two large drainage holes, and is about 2" deep. Cross your fingers this works okay!
I also have cactus liquid fertilizer, but am unsure if I should use it yet.
Solution Pic, too view
Christy B.
  • 1,225
Well, as I said in comments, not sure what this plant is, but it looks some kind of Crassula maybe. Looks much better now it's repotted, I just hope there's a drainage hole or two in the bottom! Now you've decided to give the offshoots and their roots a chance by resting them on soil, just keep an eye on them - if you notice any rot developing on their stems, remove them immediately. You should not be afraid to do this if necessary - so long as the central part of the plant, where the main rootball is, remains healthy, it will produce more shoots and growth even if you do have to cut some off. And well done for managing to do it - it must have been a delicate and rather fiddly task.
