I've been having a venus flytrap plant (actually, 3 plants in the same pot) for about 8 months.
It was greeh and healthy, but about 4/5 months ago (summer here in Spain) it started to become black and dying. So I moved from the balcony to our living room, where it has no direct sunlight but more "regular" temperatures.
I was pretty sure it was almost dead, but to my surprise, a couple of months ago the plant started developing new leaves again (although the traps seem not to fully develop). I don't directly water it, I put water in a plastic recipient from where it can absorb the water (distilled water)
And I've recently discovered that the tall stem you can see in the picture is actually a flower bud.
So, I wonder if now that it is going (hopefully!) to blossom, it has different needs on water/light/whatever.
Any advice? Thanks!
motagirl2
  • 365
A general answer because nobody is answering yet.
If it is flowering, it means that you cared the plant correctly. I would keep the condition you did until now. Often flowering phase is not a high requirement phase: the plant flowers when it know that it can afford to flower (so it is sometime difficult to have flowering plants).
The difficult phase is the next one: having fruits/seeds. If you care about these, you should probably manually pollinate the flower, and possibly get fertilizers, water and sun, in order to build fruits. In this case, the fruit is small (and ovary already developed), so I would keep it as you are doing., and correct if I see that plants is "complaining".
Giacomo Catenazzi
  • 14,822
  • 44
