Last year I bought a potted mini rose. When it started doing poorly on the windowsill, I decided to let it try its luck outdoors. It turned out to be two plants and they both took off. Here's one last year:
Mini rose
As you can see, it's up against a shed. This is southern Ontario and the front faces south. Between those things, I was hoping it would survive the winter. I also built up the soil around it to shield the roots a little more, but I don't really know what I'm doing in this department.
But the sad result this spring can be seen in this gallery.
Just before I dig them up and put something else there — maybe full roses, since one has done well a few metres away — are they as hopeless as they look or can I revive them?
Luke Sawczak
  • 548
Gosh I hate to be the bearer of bad news. Hopefully this will never happen to you again. Those roses are completely dead, pull them and dispose of the soil, bleach the pots before using again.
Mini roses from a florist are meant for using but a short time. The biggest mistake you made was to take that plant from indoors to the out of doors without the normal 2 to 3 week period of acclimatization. Usually those mini roses do not do well transplanted to the garden even with proper acclimatization; they are usually wimpy in the lower zones. If this rose is in a pot (not sure) those roots are now exposed and vulnerable to the cold. Plants acclimated and growing in the garden soil will be fine as long as they match your zone specifics. Plants in pots have to come indoors or in a heated greenhouse or die. I would never transplant a mini rose into any zone below 6 into the garden soil. Those plants are pretty much short term perishables.
Remember to ask us before you do anything with plants or the garden or the landscape so we can save you lots of time and money. Honest.
stormy
  • 40,664
  • 76
