Help needed to confirm if these are indeed whitefly larvae and what I can do.
It's October (going into winter here) so I brought my herbs indoors a few weeks ago, only to have this pest.
Questions: 1. Can anything be done to remove the white spots from the leaves? I think this is the larvae. Right now I've moved the herbs back outside and the whiteflies have disappeared (too cold), but as it's currently 45-55 F here (7-12 C), I'm worried how long my plants (esp basil and parsley) will last.
  1. Can I eat the parsley with the white dots? Even with aggressive spraying, vacuuming the leaves, and scrubbing with water, I can't remove them. I doubt they're harmful, but not very palatable. I'm seriously considering chopping off the parsley early for the winter to end this pest.
  2. Will these spread to other herbs? There's also snow-like shedding in the soil. So far, these have not spread to my other herbs beside it (basil, rosemary, thyme, mint, chives). Are any of these others significantly at risk, or just parsley? Should I trash the soil (these are in pots) completely rather than risk larvae next season?
Please share if you can help.
enter image description here enter image description here enter image description here enter image description here
Alina
  • 5,484
  • 49
Lanna
It's certainly a heavy and probably longstanding infestation of some type of whitefly by the looks of it, but that's quite unusual on plants growing outdoors which aren't brassicas in the UK and Ireland. If its whitefly,they usually fly up in the air when you wave your hand near the plant - these insects don't look exactly like typical whitefly either, but I see eggs larvae and adults in the photo. Regardless, you can try spraying with a pyrethrum based product such as Bug Clear Gun for Fruit and Vegetables, but to be honest, the infestation is so bad I'd recommend digging them up and disposing of the plants. The white marks you could not remove from the leaves are where the aphids have been sucking the sap and caused damage - if there are no insects or eggs on some of the leaves, you could eat them even if they're marked, but I'm not sure anyone would want to.
You are right to be worried about cooler temperatures in regard to the Basil, but if it is as heavily infested as the parsley, I'd recommend disposing of that too. If you had any of these plants in the house for longer than a day or two, best to check any other indoor plants you have to make sure they are not now affected by the same problem.
