A while back I threw out some spoiled-looking garlic cloves only to find them growing quite well in my compost. I'd like to try planting a few (in a container, not the open ground).
Can I simply stick them in the soil and water, or do I need to cultivate the clove first in some way?
Lorem Ipsum
  • 11,219
  • 58
  • 95
wxs
  • 385
If you want to grow garlic, buy some "seed garlic" instead of using leftover cloves from the grocery store. It will still just be regular garlic, and you'll plant the cloves, but sometimes grocery store garlic is treated to prevent sprouting. You'll also notice when looking at a catalog that there are many varieties of garlic, and you'll be able to choose a variety that is most suited to your local growing conditions.
Select a planting site with deep, loose soil. pH will ideally be about 6.5 -- similar to what other garden vegetables like.
Plant garlic in autumn before the ground freezes -- but not too early, you don't want it to put out any top growth before winter. Mulch with a thick layer of straw or autumn leaves. (Last year I used about 8" of leaves with good results.) Plant only the larger cloves, which will produce larger bulbs. Save the small ones for eating.
In the spring, pull back the mulch before the weather warms and the plants try to send up shoots.
See this question for information on harvesting.
bstpierre
  • 41,932
  • 118
  • 240
Yeah you can put them in almost anything as long as you don't let them dry out totally..
If I remember correctly they are grown by sowing in the fall and harvesting in early summer.
Grady Player
  • 5,212
I put an extremely superficial lengthwise cut to the husk on the clove, then leave the clove in shallow water overnight. It sprouts within 24-hours, at which point I move the sprouted clove to the soil ~ 3" deep.
Everyone
  • 111
