I'm no "gardener" but I like to plant from seed and watch things grow. I am trying to learn a bit more as I go along.
I planted the zinnias in the photo below a couple of months ago, started indoors and then transplanted. My porch garden only gets a few hours of direct sun so maybe that is why they are not further along.
My question is about "pinching back" – and if there are some plants that don't like it. I pinched back #1 and #2 in the photo over a month ago. #1 clearly didn't like that. #2 rallied but is much further behind #3 (the, ah. . "control group").
Is it just simply that a zinnia isn't a "bushy" type plant so pinching back is not appropriate and even detrimental?
spring
  • 239
Most annuals respond well to pinching out, especially when you're growing from seed, but the problem you have is that your seedlings have been in their shallow tray too long - seedlings should be transplanted into pots when they have their first or second set of true leaves,so they can form a good root system prior to planting out or putting into larger pots. Further info on pinching out zinnias here https://homeguides.sfgate.com/happens-trim-zinnias-back-44409.html
