We want to keep costs down, but want something that will last, that wildlife can't get in and our critters can't get out.
Saw 6ft high steel fencing with rectangular mesh that got smaller at the bottom (for rodents).
Wildlife: deer, skunks, coons, rodents Critters: Couple of German Shepherds, chickens, maybe goats Terrain: somewhat hilly, Northern California terrain (rainy winters, hot dry summers)
DOUG BELL
Hello & Welcome Doug,
You left coyotes & cougars off your list. There is no way to keep out Raccoons. They can climb any fence. Deer can leap anything lower than 8'. Skunks & rodents can dig there way in. Unless you put up a concrete barrier both below and above the ground.
Most fences as long as they are not too low will hold most dogs, unless they are diggers. Chickens need to be in a coop/hutch at night or skunks will kill them, as well as owls, raccoons, & coyotes. If you get chickens you will attract rats. The chickens can run around in the daytime, but you risk Hawks picking them off unless you keep them in a large enclosed area at all times. Goats need enclosed building to go into at night. Otherwise they are easy cougar prey.
You can install a 6' tall cedar fence with a 2' lattice on top. That will keep the deer & coyote out. Other than that you moved to Northern California.
Welcome to Cascadia.
GardenGems
  • 2,408
It is difficult. The best method: look around you, to see what other have done, and ask how their method is effective. There is a lot of try and error loop, and it is good if the "error" part was done by others ;-)
An option is to use the electric fences, ask to a local dealer: it depends on soil, vegetation, and wild animals which and how to set up an electric fence: you need probably many lines near (and maybe below) soil, for the small games. You can have the electric fences with are powered with a solar panel (and a battery for night).
Maybe you need an hydrid one: steel fencing with rectangular mesh for the very bottom part (and also undersoil! or rats will dig a hole to pass), and above the electric fence, so that nobody could pass over it.
Giacomo Catenazzi
  • 14,822
  • 44
