A little over a year ago, after complaining about the amount of cord I had to use with our electric leaf blower I was gifted an inexpensive gas blower. A Ryobi 150 mph 400 CFM Gas Blower Vac from home depot to be precise. It probably wouldn't have been the one I would've chose, but hey. Complaining about gifts is never a good idea.
I mixed up some gas for the two stroke engine, but admittedly I did eyeball it. It started right up, and worked great. I used it for the next 30 minutes or so until it ran out of gas. At this point I needed to buy some new gas. I mixed up this next batch very carefully, and about two weeks later I went to use it again. It would not start, didn't start. Its a year later and If I was going to return it I should've done it months ago.
I'd like to get it started, but have little experience with trouble shooting small engines. I am a computer programmer, not a lawn care specialist. But, I'd love to learn. And I do have an internet connection. I am a bit stumped. Where should I begin. What could be wrong?
note: looking at the reviews online this 'not starting' or tough to start seems to be a common problem.
bstpierre
  • 41,932
  • 118
  • 240
matchew
  • 235
Here's what I've done on my two-stroke chainsaw when it has refused to start:
  • Remove and replace spark plug; check the gap.
  • Remove and clean [with an air compressor] or replace air filter. (I just blow it out, I haven't yet replaced the filter.)
  • If you see gunk when you're removing these parts, clean it up. (Because of all of the sawdust and bar oil, the chainsaw accumulates a lot of gunk. I don't know how dirty your leaf blower will get.)
These are very easy steps -- I'm usually a complete failure at engine/machine repair and even I can do these without ending up with a pile of parts that I have to bring my friendly local mechanic for reassembly. For tools, you'll need a spark plug (deep) socket, an air compressor with a blower fitting, and maybe a screwdriver to open the engine case.
I've also seen replacing the fuel filter as a suggestion, but haven't needed to do this yet. The steps above always get it restarted.
bstpierre
  • 41,932
  • 118
  • 240
