I'm super new to having plants/gardening. 4 days ago (as of writing), I purchased a set of herbs online from a seller just a city over. Here they are when they arrived: set of herbs
Now though, they're starting to look unhappy, for lack of a better term. The stems are turning dark, although they're not squishy. Some leaves are also yellowing and/or getting brown spots. I haven't watered them since I got them, I just removed some of the yellowing/dried leaves. Kind of scared to do anything yet.
Lavender:  Sick lavender plant
Parsley: sick parsley plant
Peppermint: sick peppermint plant
Basil: sick basil plant sick basil stem
PS: apologies for the photos being screenshots, the original's file sizes were too big for upload.
gfish
They may not be accustomed to sunlight, so that might have caused a problem, but the main issue is probably lack of water. Water when the surface of the soil feels just about dry to the touch, water well, allow to drain down freely. Check them daily to see if they need water, especially if the weather is hot and sunny, when they might need watering twice a day because the pots are small. Acclimatize them to sunlight gradually, but the parsley may do better in partial shade anyway.
The lavender needs a larger pot so find one the next size up and move it into that; use new potting soil to put round the root ball and water well when it's done. You will probably need to cut off the parts that have died back, right at the base of the stems close to the soil. The Basil is okay at the moment, but will likely need a bigger pot soon, as will the peppermint. Moving them out of the rain is not necessary, unless it's raining so hard its battering trees and large plants to the ground with the force of it.
