I want to place some plants in the borders of my terrace garden. The house has a large amount of ivy running up the side of the terrace. When tilling the soil, I've discovered that it's completely full of tiny, fine roots, spreading out from the thicker ivy roots. I've cut out some of the clumps of fine roots and some of the thicker ones too that have grown throughout the soil. However, am aware that it will all rapidly grow back as the main source has been left untouched.
Is it possible to actually plant anything in this soil or will the profusion of ivy roots prevent anything from growing?
fortunia88
  • 191
Ivy is almost impossible to remove. There are a few ways to deal with Ivy . . .
The easiest way for you, since you have already dug out and removed a lot of Ivy roots, is to just keep careful watch for any Ivy foliage that has started to grow back in the area you don't want it in and remove it. Other plants can grow around the Ivy roots if the growth of the Ivy is kept in check. Choose plants that can grow with shallow root systems, like Impatiens and Moss Roses.
Another way is to spray herbicide directly on the Ivy roots. You would have to be very careful not to allow the herbicide to touch the roots of any plants you want to keep. Herbicides only last for a short time so you would have to keep spraying the Ivy roots every few weeks. This may or may not interfere with you growing other plants in that area, depending on the specific plants you want to grow there.
Finally, you can cover the area with about 6 or 7 inches of mulch. The mulch will block the sunlight and prevent the Ivy from growing back. However, it will also keep any other plants from growing there too. I have used mulch to keep Ivy from growing in places that I didn't want it to and then just not put down mulch in the places I wanted to allow Ivy to grow.
Avlar
  • 864
You definitely can plant new items on your terrace garden--but it may take some time. If you're comfortable, you can first spray the area with a chemical herbicide such as glyphosate--but this is optional as I do not typically do this. If a chemical herbicide is not an option for you because you're going to plant something you will eventually eat or your not comfortable with glyphosate, then you can try to remove all the vines and as many of the roots as you possibly can. After that mulch the bed with 2-3 layers of card board and add a heavy layer (1-2 feet) of wood chip mulch. This should do the trick. But you'll have to monitor and continue to remove any new vines that develop. I'd wait about 2-3 months until to landscape the area.
JRap88
  • 356
Interesting question; the soil may be depleted, so when refilling, maybe consider fresh soil. Before refilling the hole, place a thin vertical solid plastic barrier material around the perimeter of the excavated hole to stop/slow incursion of new roots, that extends down deeper than the bottom of the hole. The hole would have to be deep enough to discourage vertical upsprouts of ivy from remaining roots. A barrier on the bottom of the hole might also be beneficial. With the soil preparation the garden should be fine!
Would suggest Not using any artificial spray etc on the ivy roots: doing so would make the hole unsafe to work in & around, it might eventually get into the water supply, it might ruin the ivy extending up the walls, which would then need to be removed, and would leave an unsightly gap in the live ivy growth on the wall. For a long while nothing would grow well in the hole, and if it finally did, it would be unsafe to handle or to tend.
M H
  • 1,140
First make sure you are in shape, as you will be doing a lot of bending and pulling. Your going to need 1) A quality pair of gardening gloves 2) gardening or construction shovel Begin by removing the surface ivy and ivy branches. To do this, grab as much surface ivy as you can and give a good yank. A lot of the ivy branches a intertwined with eachother thereby allowing you to rip out a generous amount of ivy and ivy branches After you have removed at least 2 sq ft of surface ivy it is time for the real work. Now you will getting down to the deeper and thicker roots. You may even be able to see some thick root potruding from the surface. Try at first to get a nice grip on the root and give a hard pull. The root may be long so keep pulling it as much as it lets you. The idea is to get the whole root at once but often times it breaks before reaching the end of the root. In this case, just dig down 2 or 3 inches, grab the part of the root that is still in the ground. If it is still stubbornly not bugging, you may need to use your shovel. Dig down 2 to 4 inches beneath the root. With shovel beneath the root, lift up on your shovel. This should expose more of the underground root. If able, using your hands, pull the root up. You will be able to get a sense which way the root is heading so continue to pull in that direction. This step may need to be repeated as often as the root tears off before reaching the end. You will know when youve reached the end of the root as you will see a cluster of mini braches that look a lot like nerve endings. One time a single root ran halfway through my yard. Sometimes more roots are hiding beneath the dirt so you want to do a little hand digging. Before moving on, do another inspection for any other roots that maybe lying beneath the surface.
