We are planning to marcot Mango, Chico and Duhat.
Approximately how many days after marcotting each of these respective plants will the roots begin to appear?
We ask because we live in the equatorial regionPhilippines, and we would like to do it right the first time.
Per Wikipedia:
It can take the layer from a few weeks to one or more growing seasons to produce sufficient roots; this is largely dependent on the plant species and the vigor of the parent plant.
Edit (September 2, 2020) Daytime temperature in our place ranges from 34 degrees to 38 degrees Celsius. Nighttime temperature ranges from 28 to 33 degrees Celsius. It is very humid here. There is the Laguna Lake nearby (so would that qualify for maritime climate?). About the particular Mango species to be marcotted, I am not particularly sure about the scientific name, but I am attaching herewith a photo of said (ripe) Mango: enter image description here
We are still uncertain about the following:
  • diameter & ages of branches intended; and
  • specific air layering methods intended
Are there prescribed procedures/methods for these, with the background information that I have given so far?
The best time to marcot your mango trees is when they are producing new leaves. I don't think you have a proper spring as such where you are, which is when marcotting would be done in the northern hemisphere, but even so, you may get faster rooting earlier in the year than you will now. However, you will obviously know when your tree is producing new leaves and is in active growth, so try whenever that is happening. Although this really applies to marcotting in more temperate zones, there is general guidance on this procedure here which should be helpful to you https://homeguides.sfgate.com/right-time-year-air-layer-deciduous-tree-47240.html.
Length of time for roots to be produced is usually 2-3 months, but it does vary depending on conditions. In terms of selecting the right size stem and having a visual step by step guide to the procedure, there are many Youtube videos on line which you should be able to access by googlig 'marcotting a mango tree', but here is a link to one example https://youtu.be/P_XSFtP3atk
