Context
There is a what I believe to be a small dogwood in my backyard very close to the house. Fox squirrels frequently jump from the tree onto my roof. They all use the same spot on the same branch. The branch is, as a result, frequently getting scratched and damaged on that spot. The branch is thinner than a paper towel cardboard tube. Image below.
Questions
Should I treat the branch?
Is there a way to protect the branch from future damage?squirrel damaged branch
Notes
I do not want to remove the squirrels or otherwise harm them . Also given my area removal isn't an option given their very large local population.
Rorschach
  • 113
Tree Guards or tree trunk protectors are commonly available at nurseries or farm supply stores or Amazon too. They are a flexible plastic tube with holes to allow drainage and venting and they have a "memory" so they stay rolled up.
If you bought one on put it around the branch that should do the job nicely as the diameter of the branch in the picture is a close match for the newly planted saplings it is normally used for.
kevinskio
  • 62,221
  • 167
