19
We have a lot of oak trees on our property. Is there anything we can do with the oak leaves? They never really seem to break down, and because of that, I am afraid to try and add them to a compost. Are they useful in composting at all, or should I keep them out of any mix I make?
When I rake them, I have been chopping them with a leaf blower that breaks them up so I can fit more into a bag. I am not sure if that makes them more useful. I'd like to use them if I can, but if it's not wise, then I'll not try.
Lorem Ipsum
  • 11,219
  • 58
  • 95
MichaelF
  • 799
10 Answers10
19
I've made a special pile for leaves. It's helpful to contain it, at least at first, to prevent them from blowing away and making a mess. I just took a length of wire fence and turned it on itself to make a circular "pen" for the leaves.
It takes them much longer to break down than regular compost (at least a year, probably two), but the end result is leaf mold, which is a low-fertility soil improver. You can mix this into your garden beds to improve the soil structure and add organic matter without adding a lot of nutrients. Earthworms love leaf piles; when I turned a big pile (1/2 sq yd or so) into my garden this spring I imported tons of worms along with it. The chopping that you're doing will help the process along.
bstpierre
  • 41,932
  • 118
  • 240
18
Everything is compostable, even you! You're right, you ought to chop them up before trying to compost them, you also need to add some dirt and maybe grass clippings to your compost in order to convert the leaves into compost.
I'm pretty sure dried oak leaves do not offer a lot of nutrients to your compost, but another thing you could do after chopping them up is till them into your soil or use them for mulch, if they never break down, that's actually a good thing!
Travis Northcutt
  • 436
Peter Turner
  • 9,211
  • 40
  • 83
One good use for oak leaves is as an overwintering blanket for tender plants. Unlike maple leaves which tend to lie flat and create an impermeable sheet, oak leaves curl. With enough of them and a tomato cage, you can make a nice blanket which will protect your plant from the desiccation of winter winds
Lorem Ipsum
  • 11,219
  • 58
  • 95
kevinskio
  • 62,221
  • 167
I know the answer has already been accepted, but feel the need to add this - piles of leaves are best composted separately from everything else, because they break down in a different way from most other stuff. If you've got room, and plenty of black bags, it's easy - just collect them up, stuff them in the bags, as many as you can in each bag and still be able to tie the top. If they are dry, water them, poke a few holes in the bottom of the bag, tie it shut and leave it somewhere out of sight and preferably not on a surface that stains, for up to 2 years. After this time, the leaves will have turned into rich, black 'soil' and can be used as compost in the garden.
I've been mowing them really small for about three years now and turning half into the garden and putting the other half into a compost pile along with grass clippings, kitchen scraps and of I'm lucky enough to be given some manure I mix some of it in there too.
user2988
Just a note, for all you who happen to have acidic soil: Oak leaves are very acidic so I would avoid using them if that is a concern.
Tea Drinker
  • 9,643
  • 114
Silver
In the fall up here in Wisconsin I pull the empty sunflower seed bags over my roses and stuff the oak leaves in around the branches for a winter insulation. Come spring I pile them together and pass the lawn mower over them collecting them in the lawn mower bag. The shredded leaves are stored in plastic garden bags to be added into the mulch bins throughout the spring and summer. Works well!
Richard
I live in a forest primarily made of oak trees. I fight "leaf wars" every year. For 15 years I have mulched the majority on a very large lawn.
The leathery leaf must be chopped as small as possible. It is a favorite food source for earthworms. Their castings and leaf mold help dress the soil and is fertilizer for grass and feeder roots of trees.
An oak leaf that is still whole, if left on the ground or in bare spots in the lawn, will stay there, blocking grass growth for many years. Rake them loose and mulch.
A very good mulching mower is a necessity. The mower blades will dull and need sharpening a time or two. The dust will clog the air filter so check and clean it often. Wear a dust mask. The result is a lush green lawn.
The down side: The worms loosen the soil so well that local moles will tunnel through your yard. No damage just unsightly. Poke holes in their tunnels. They don't like air and light and will abandon that one. Continuing this until they return to the woods may take a while.
I do blow mass amounts of oak leaves back to the wood line. That "berm" is gone, composted by the next War.
I must return to the war. Good luck!
  • 7,289
  • 81
I rake 'em into a small enough to handle piles, and use my mower (mulcher), to break them down. I have found a lot of plants, spider plants, wondering jew, orchid cactus, etc, love it just as it is broken down. What I don't use for planting, I throw into either my compost bin, or fill up holes and stuff around the property.
Yes you can use oak leaves as compost. Use your mower to suck them up into the bag then sprinkle the bag over area
Ami Walton
  • 49
