I am attempting to remove what I believe to be a small privet tree. It is planted in a raised bed and has been here for several years. I cut the main trunk off a couple of years ago, but it has since thrown up several new branches from the stump, and now I want to get rid of it.
There are some quite stubborn roots that appear to extend for a few feet. It will be a lot of work to remove all the roots, and will involve disturbing other things planted in the vicinity, including bulbs that are about to flower.
My question is: if I sever the roots, will they grow back? They are probably an inch think and hardly budging even 18 inches from the stump. They are growing down into clay with lots of stones.
Stump
Root
Thank you.
EDIT One hour later - root (mostly) out: enter image description here
greenback
  • 123
I would suggest a couple of options. First, dig out the stump using a mattock. There's a YouTube video here. Second, cut all the branches off and zap all new green growth with Roundup. Do this regularly and you should eventually kill it. Roundup only works in contact with green leaves, so you need to wait until they appear, then spray. Repeat as necessary and follow all usage instructions to the letter.
Peter4075
  • 4,386
