My Euterpe precatoria has had small brown spots on its leaves for some time now. Over time, these became larger and larger, turning into large brown spots. Recently, however, the green leaves have become completely brown and dry and die off after a while, causing the whole shoot to die.
Now, for the first time, a new leaf has also turned brown while it was still curled up and growing. After the shoot unfolded, several of the new leaves were already brown and dry.
It is in a rather loose soil with sand, perlite and expanded clay. Its pot is a so-called fabric pot with good ventilation and drainage.
It is kept in my indoor greenhouse all year round at a relative humidity of between 75-90% and a temperature of approx. 25-27 degrees Celsius (77F - 80.6F). The greenhouse also has a shading net (60%) so that they don't get too much direct sunlight.
I rarely fertilize them and when I do, I use a complete fertilizer plus extra iron fertilizer.
As far as I can see, it has no pests.
I've also spent several hours googling but I couldn't find any comparable symptoms. Unfortunately, there isn't much information about the Euterpe precatoria anyway.
I would be very grateful for any tips on what it might be missing.
newest leaf soil in a pot
More images can be found at imgur - more palm photos
kevinskio
  • 62,221
  • 167
undefined
  • 133
Looks like fertilizer burn to me. Also, palm trees prefer sandy loamy soils over highly draining gravel. The gravel retains too much moisture and fertilizer, which in turn is drying near your root area and remaining concentrated throughout their. Also, do you use correct NPK proportions? This looks more of oversaturated nutrition case.
Jayparth
  • 1,356
