I have never hot-water scarified seeds myself, you just got me curious. One thing that startled me was that I could not find any species that absolutely required hot stratification to germinate a seed. All species I saw that benefit from hot water could germinate (less successfully) without it and would also benefit from other, cold, stratification methods.
Using Iliamna rivularis as an example:
The control treatment (intact seeds) yielded poor germination (1.8%).
Mechanical scarification (part of the seedcoat removed) improved
germination (average germination 49%), but not as much as the
combination of boiling the seeds for 120 s plus stratifying them 28 d
at 4 °C (average germination 70%). Germinants from the boiling plus
stratification treatment appeared to be more vigorous. Impermeability
of the seedcoat is the main factor preventing germination, but the
response of embryos to stratification may suggest some physiological
dormancy.
They only boiled the seeds for 2 minutes. Limiting the heat exposure is a common theme with hot water stratification.
The Seed Collection
The water temperature should be about 82 degrees Celsius. Soak the
seeds until the water cools.
University of Kentucky
Hot water treatment can be accomplished by dropping seeds in water
that has just begun to boil. Remove the boiling water container from
the heat source and allow the seeds to soak for 1 to 10 minutes
depending on the seed type. Too long an exposure to the hot water can
kill the seed.
BMC Ecology
The rupturing of the seed coat may be induced by heat from fire [10]
enabling water to enter the seed and start the process of germination.
Many studies have confirmed a release of legume seeds from dormancy
after fire [10-17]. Fire temperature or intensity also has an effect
on the germination of seeds [17,18] and low intensity fires may not be
enough to break dormancy of hard-seeded legumes [19]. In other cases
The rupturing of the seed coat may be induced by heat from fire [10] enabling water to enter the seed and start the process of germination. Many studies have confirmed a release of legume seeds from dormancy after fire [10-17]. Fire temperature or intensity also has an effect on the germination of seeds [17,18] and low intensity fires may not be enough to break dormancy of hard-seeded legumes [19]. In other cases lower fire temperatures are preferable for germination with an increase in fire temperature causing seed mortality [18]. [18].
Getting to brass tacks, SEED GERMINATION THEORY AND PRACTICE by Dr. Norman C. Deno (First Supplement) (Second Supplement)
Many Fabaceae (legumes), a few Malvaceae, and a few other species use
impervious seed coats as the mechanism for preventing germination
before the seed is dispersed. It is not clear whether the mechanism
operates by excluding water or oxygen or both, but what is clear is
that grinding whole through the seed coat• produces a dramatic effect
with the seeds germinating in a few days after puncturing the seed
coats and placing in moist media. ... The dramatic effects of
such pretreatment of the seed is shown in Table 9-1 at the end of this
Chapter. The favorable effects on germination induced by various
grinding and abrasion procedures has long been known. This subject is
treated in recent books under the title scarification. This term
should be promptly abandoned because producing a scar on the seed coat
surface has no effect. Only the formation of a true water channel and
hole through the seed coat will reliably and reproducibly give
immediate germination. ... It has often
been recommended to soak seeds of this type in hot water or to pour
hot or boiling water over the seeds. An example taken from the
Thompson and Morgan catalog is to immerse seeds of Mimosa pudica in
140 deg. F water for twenty minutes. I have verified the effectiveness
of this procedure. Prof. Roger Koide at Pennsylvania State University
has found that ten minutes in water at 140 is effective for Abutilon
theophrasti. The Thompson and Morgan catalog recommends soaking in hot
water for a number of species, and it can be inferred that these have
impervious seed coats. There are two problems with these hot water
treatments. The optimum conditions vary with each species and have to
be determined, and the results are generally less effective than
physically producing the hole in the seed coat as shown below by the
results with Gymnocladus dioica. The hot water treatments work because
the heat causes expansion of the seed coats. This causes microfissures
to form and in effect a hole has been produced in the seed coat. The
extensive studies described below on Gymnocladus dioica are all in
accord with this interpretation. Inferences in the literature that the
soaking softens the seed coat are incorrect, although the seed coats
then soften in a day or two due to enzymes secreted by the activated
seed.
So, how do the seeds survive?
- They are not brought fully up to 100°C by letting the water cool or limiting their time in the bath
- The seeds are protected by a impermeable layer that takes time to pass.
- Biology is just crazy.
Intuitively I think of times I've placed my hands in too-hot water for several seconds and been fine afterwards. Like making mozzarella.
